I will add variable timeout setting, now it is fixed 2 seconds.
But the other zy is working or also broken? Can you please try to connect with putty? So when putty is working, then my app is fault, otherwise itās your zl1100. Anyone else here with a zl1100 for testing?
Regards
Patrick
Edit: my zy only times out when I display the chart screen on it, other screens donāt cause a Time out
Welcome to BLF Franky. If you happen to find out who could sell the power banks, let us know. I would think someone could sell quite a few of them if there was a solid place to buy them from, especially if they were converted to English.
Pardon my ignorance, how does one connect a serial-USB adapter to the ZY127x meters? Does the ZY127x meter have to have the bluetooth module installed for this to work? Or just need to buy some kind of serial-to-USB chip and (temporarily) connect it to certain contact points of the ZY127x meter?
I also have the ZL1100 load tester, and getting same error message as maukka above.
I actually havenāt tried to connect the ZL1100 tester to the computer yet before, so itās my first time to test it connected to the PC.
(Iām not familiar how to use Putty, but I searched and downloaded a free software called RealTerm, opened the correct COM port, and it started to log results on the window); I had to use āRun as Administratorā to get RealTerm to work:
The above image correspond to reading of 5.0097v, 0.1000A, 0.9869Ah, 11.3322Wh
The āCPSā status window fluctuates between 740 to 1110 cps.
Not sure if this will help in debugging your great app.
Find the 4 solder pads near the edge of the main PCB. Starting from the square one, connect the 1st, 3rd and 4th solder pads to the GND, RXD and VCC of your serial-USB adapter.
Argh, I am frustrated! ā¦because Iāve had my zy1276 for a week and havenāt gotten a chance to play with it, lol!
Lots of great info here, thanks all! Canāt wait to use itā¦ :person_facepalming:
Sheesh, why does life have to be so busy that I canāt spend every day tinkering with my hobbies? Well, I did get my EBD-USB+ up and running yesterday, thatās good.
edit: one problem, when trying to save the chart, it says āthe system cannot find the drive specifiedā. Iām running the software from C:. Or was this feature still unfinished?
you can specify the path in the settings. then when connected, press play, then press pause, then go do the cart, then you should be able to save it, BUT yes, this feature isnt finished and tested, so please be patient.
The ZY1276 firmware v3.35C (it seems to indicate 2017/10/22) includes a test for Apple MFi, unfortunately Iām not sure where the firmware might be available for download ā I believe one has to join a China-based WeChat/QQ group to get the firmware update?
Purchased a ZY1276 from ebay seller 6999694 in late December. Delivery took approx 9 business days via included (free) ePacket from Shen Zhen to the Central US.
Construction seems solid and the LCD is vivid. The charge rate/power detection appears accurate after testing and comparing the documentation on a number of different make/model power banks and wall chargers.
The unit arrived with firmware 3.35G with default language of English. No instructions were included but I was able to figure out basic operation from the ZY1270 manual found at www.kaayee.com/download/.
For those asking about the apple MFi check - I havenāt figured out a way to perform this test.
Update on the MFi check:
* A Quick Charge 3.0 capable power source is likely required to activate this test.*
1.) Repeatedly press select button until you are on Screen 3 (Voltage / Current / Power + DATALINE + PROTOCOL)
2.) Long press select button to activate the āFastChargeTriggerā menu.
* WARNING* Make sure nothing other than the power supply is connected at this point. You take the risk of accidentally over-volting/destorying any connected downstream electronics in cables or devices depending on your power suppliesā capabilities and the Fast Charge menu options you choose! Itās easy to accidentally trigger >5V voltage output in this menu so consider this warning.
3.) Press button twice to select āAre You Sureā? (As a safety measure - If a connected device is detected this option may not be available.)
4.) Long press button to enter the Fast Charge Trigger menu.
5.) Press button repeatedly to navigate to the āAppleOldMFiā menu item (last on list) and then long press to start the test.
6.) You will be prompted to connect the power supply side of the MFi cable and press button to start test. Cycling power will take you directly back to the āAppleOldMFiā test menu until you manually exit by long pressing the button.
Notes:
If connected to a typical 5v only USB power source, the MFi test will fail saying āNot Allowedā. After a good deal of trial and error and some additional research I found a different brandās USB power meter MFi check requires a Quick Charge 3.0 power supply for the test. It appears this test requires 6.5+ volts.
After locating a power bank with a QC 3.0 port, I tested every Apple cable I had on hand and found the following:
A.) 10+ Apple OEM lightning cables passed both the first 5V and second 6.xV tests as expected. These cables included the original thinner and the slightly thicker cables shipped with the newer ipads and iphone+ size models.
B.) A single new Apple OEM cable failed the first test (test 2 auto skipped) and was detected as a Fake. Iām fairly certain this is a previously unused cable that came with an iPhone X or an 8. However the cable works fine for full rate (12 Watt) charging a 50% discharged iPhone X and iPad Pro 10.5 on IOS 11.2
E.) Cheap 4pk of āG-Cordā labeled 6ā cables from Amazon - Failed first test and labeled as a fake. However this cable charges a 1/2 charged ipad Pro at 11.75w (5.00v/2.35A). It also charged an iphone 5s @20% charge with very aged battery at ~4 watts.
Iām not an MFi certification and spec guruā¦ if I had to guess, the MFi test performed was for an older MFi specā¦ hence the label āAppleOldMFiā.
Someone with more knowledge of MFi certification, specs, and changes between them please chime in.
