Air Cooled 4x XHP50.2 UPDATE: Videos, Willing to sell
48 posts / 0 new
Kourtinoksylo
Last seen: 2 weeks 6 days ago
Flashy Mike][quote=Kourtinoksylo wrote:
So the electrical contact for batt- is done only by the 2 tubes connected with epoxy? Since I have a somehow similar mod in my mind I wonder if over the time the pressure between the 2 tubes decreases and the contact resistance rises. The tubes are nice, they look similar to the Q8.
Yes you are right, over the time it could happen. You also need to have both surfaces very smooth and gapless before gluing , and use some weight while it hardens. The current doesnt flow through epoxy and the screws but through the exposes aluminium where the 2 tubes meet.
Now if the tubes loosen with time and I lose contact, a possible solution is to drill one or more small holes exaclty between the 2 tubes(in the gap) and insert a short piece of singe core copper cable or similar conductor (with a tight fit) to reconnect the two parts. If you find a conductive epoxy, it would be the best solution in first place…
To the other memebers asking about temps and beamshots, until now I didnt have the time to use the flashlight enough. I will try in the next days to do it, and write back.
-Air cooled 4x XHP50.2: http://budgetlightforum.com/node/56829
-SkyRay King 4x XPL HI, TN40 clone: http://budgetlightforum.com/node/55195
-XHP70.2 Maglite 2D: http://budgetlightforum.com/node/54791
-SkyRay King 7x XML2, TIR, 8x 18650: http://budgetlightforum.com/node/54886
zelee
zelee's picture
Last seen: 3 months 1 day ago
my reaction was WTF Shocked
same as the brand of the fan you use
Don’t mistake my kindness for weakness.
I am kind to everyone, but when someone is unkind to me, weak is not what you are going to remember about me.
KawiBoy1428
KawiBoy1428's picture
Last seen: 44 min 49 sec ago
I inserted some 3mm screw rods in the exsisting holes of the spring board and let them stick out around 12mm as you can see on the picture. I then drilled four 5mm holes roughly at the appropriate spots at the second tube as you see on the same picture. 5mm allows some room to play and find the perfect fit. I filled the 5mm holes with epoxy and placed the tube with the screws on top of, with the screws being inside the epoxy. After it hardened they became inseparable. I suppose if i heat the pieces a lot and melt the epoxy I can separate them if needed…
The SRKs I used where the cheapest I found on aliexpress that had the smooth type tube. Were around 15-17 dollars a piece. They are I think 10 or 11x XML.
Thanks for the info. So the electrical contact for batt- is done only by the 2 tubes connected with epoxy? Since I have a somehow similar mod in my mind I wonder if over the time the pressure between the 2 tubes decreases and the contact resistance rises.
There are other techniques that assure electrical contact between 2 SRK battery carriers.
They can be threaded on one side, pressed fit and pinned together with roll pins (4) of them and then epoxied.
KB1428 “Live Life WOT
Kourtinoksylo
You are right! I have done this in another 8 cell project, the last one in my signature. Its 1s8p with 2 tubes. This time I wanted to avoid the conencting ring for a smoother look. It is more practical with the ring though, as you can unscrew it if needed.
KawiBoy1428
You can still roll pin, or get really fancy and use brass pins, and on the PCB side, use the 4 PCB mounting holes, drill them out for the pins, press together and epoxy. You just have to drill and tap M2.5 or M3 for the new PCB location on the one end.
KawiBoy1428
Well we need a BLF Museum of Fine Flashlight Art! Wink
This one needs to be in it!! Love Thumbs Up
CRX
CRX's picture
Last seen: 5 hours 21 min ago
Very nice Thumbs Up
Flashy Mike
Flashy Mike's picture
Last seen: 2 weeks 1 day ago
Yeah. I guess I would choose the option of screwing them together with a threaded ring, similar to Kourtinoksylos’ previous mod, but the ring should have twice the height of the tailcap to fit nicely. It’s a pity I don’t own a lathe.
mizou51
very very nice !!!
Kourtinoksylo
I dont have a lathe either. Just cut the plate of a tailcap like this picture, then epoxy the non threaded side to the back of first tube leaving the tailcap threads free so that the second one can be screwed.
Flashy Mike
I have seen your mod earlier and like the idea but still would prefer a ring of proper size which can be screwed on both sides and allows to separate the tubes with little effort later. But if I don’t find a fitting ring i consider to use your approach too.
KawiBoy1428
All done by hand, no lathe at home, not yet…….
Kourtinoksylo
FireFlyMod wrote:
Pure EDC Big Smile
Haha with 1300gr=2.85 pounds it needs a backpack. It is a cometitor for the BLF GT in terms of mass.
I started to make some meassurments for the effectivness of the heatsink. I need to top up the cells between every test to keep the results consistent and this takes a lot of time. First results show little difference in turbo as we are dealing with 335W of power and the heatsink i built is definately not big enough.
-41sec to reach 51C without the fan, cells top upped, retested: 50sec to reach 51C. So it makes no practical difference in turbo.
Other levels are being tested and I will update the original post.
Ronin42
Ronin42's picture
I think you could change your name to NL for (New Lumens) or maybe YL (Young Lumens)
If you want to sell it, as opposed to willing to sell it, you will get more nibbles if you put a price.
I know it hurts and it is hard to justify flashlight modding with $$ but that’s sort of the way a market works.
best of luck to you.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
Kourtinoksylo
Thank you! I dont really want to sell it because I like it very much and air cooled flashlights are very very rare. Apart from that I put a lot of effort in it. But if I get a price from someone that will pay off the time I consumed and the uniqueness of the design then I am selling it. I think the one that will be interested in this flashlight will be able to estimate a price. Maybe I am wrong…
I cant put a price on it, because I dont know how modded flashlights are priced.
A very famous modder, sells for example a C8 with xhp50.2 thats works only with 18350s for 100$ while on KD its 29$ for 18650 version. Or a slightly modded Convoy L6 for 165$ if I remember corectly. So he is selling for 3 to 4 times the material costs for emitter swaps or improved driver, nothing special. His special items are for sale for more than 1000$.
WillyD
Last seen: 2 weeks 4 days ago
Just saw your updated post with the youtube video. That is absolutely wild…sounds like a small turbine engine in there.
Kourtinoksylo
So I suppose the name WTF ( Wild turbo fans) fits perfectly to the fan lol. Thats why I selected 3 different speeds, on max it spins according to data sheet with 23.000rpm and it would be annoying to run always on full blast. Even my max fan mode is not the 100% the fan can push, I use resistors to limit it to around 90%.
Thanks for watching!
