Just curious, why this version with 70.2 LED has the same lumen as in Version 1,
Why not Haikelite increase more lumen with this 70.2 version ?
I've wondered that too... I have one on the way. It is still at least 10 days away but once it gets here I plan to check output first.
I do know it is possible they just kept the power at just the level for the same output as it would take less power with the 70.2's which means less heat.
If it’s the same constant current driver as before, then there is not gonna be any power increase.
You may get better efficiency or less heat. You may also get a smoother beam pattern with less dark spot in the middle. Plus it’s now cheaper to upgrade to a fet driver for more output because you don’t have to upgrade the 3 emitters.
Given specs is base on regular MT03II gen1. [quote=flybird] Just curious, why this version with 70.2 LED has the same lumen as in Version 1, Why not Haikelite increase more lumen with this 70.2 version ? [/quote]
order placed.
Thanks
Ordered. Thank you!
Too expensive but thanks for organising
ordered thanks.
Interested cw
i interest. please input me down
Interested in NW (White)
Cost price for 70.2 is high, no choice.
They are using the same driver as the first light with xhp70, right?
I wonder if lionheart meant it’s too expensive for what you get or too expensive in general? I don’t go to Acebeam threads just to say “That’s too expensive”.
I’m interested
Can you message me the price please? Thanks!
It cost less than my MT07. I was order #2 for them. Not sure if I’ll actually order this. If they increased output or CRI, it’d be an easy choice.
Order placed for a white NW, nice! Thanks Again!
It's just too much awesomeness to resist.
What’s the colour temperature of the neutral white emitter? Is it the same 4800K like the MT07S?
NW ordered.
Thanks Freeme.
5000k. [quote=hIKARInoob] What's the colour temperature of the neutral white emitter? Is it the same 4800K like the MT07S? [/quote]
