Received my copper S2+ pill and A6 spacer. Ordered on the 3rd, received on the 12th. Thanks a lot kiriba-ru!
I don’t see those in your OP. Any details about the M2 kits? Copper or alu? Do they also have an optic retaining ring or push it flush against the lens? Or do they fit for use without the lens? I think the diameter of the M2 is about right for that.
Copper spacer, aluminium optics ring, made for Carclo quad.
That’s quite the chunk How much do they sell for? Are those rings wide enough to hold the optic without a lens or are they meant to be used with the lens only?
No, you have to use stock glass lenses over tir.
$11.
Wild guess: Zoom head?
No.
Im not against if this lottery will take longer than I expexted (most future projects are paused cause small demand for stocked parts), so I dont give tips that can make guess easy.
I just want to say that chances will raise if you will use collective brain. All interested supposes mentioned in thread went this way. Amount of information that was already given is more than enough to make right conclutions.
Is it a replacement tail end for a light so that the light can be positioned to tail stand?
You forgot extra ring.
I’m guessing its a drop in. The area for the optic has yet to be machined out. It would be useful to swap assembled pills quickly.
Change my mind about it being a drop-in since ElecticJelly, already guess that AND because it’s AL rather than CU.
I say replacement bezel head, before fins and cutting in two parts for front lens holder.
Ordered an X6 cu spacer, plus Ledil Cute-3SS TIR - and I'm absolutely wrapped with them. I finally got around to fitting the spacer on the weekend. A little bit of finish sanding (as is stated in the description), and the spacer slides in so neatly, it's airtight. Really happy with it - great machining, great tolerances. The packaging was also excellent (arrived in a little plastic box with each part wrapped in foam).
I will be back for more!
Got a custom triple kit for my Convoy X3, it just fits perfectly. Will use a cute-3ss with it. I haven’t modded my light completely, just test fitted the parts. The LEDs still need to arrive, so it will take a little longer until I mod the light and take some pictures.
Very common words.
I had to say that finished design is not so simple (samples are made with manually controlled lathe so they are so austere), otherwise you could recognize it long time ago.
I picked up the parcel at the post office today and everything is ok.
The XHP50 now lives in my Olight R50 and I really like the tint.
Nothing to say about the XHP70’s though, as I failed at opening my X7R…
Thanks again for that great deal
Received my pill and and XHP70 a couple days ago. Ordered 10/23, shipped 10/23, got it 11/3. Came super well packaged. Got my order from mtn electronics the same day so my triple build is a go. One quick off topic question: how should the xhp70 be aligned on the sinkpad PCB?
Pill + LED:
Optics and MCPCBs from Mtnelectronics:
Pm sent for some pills, I need them pills.
Replied.
Lol, nice.
