Thanks for the links texas shooter Meanwhile I got a deal from a BLF member, but that’s good to know it can be found around there.
I also found the Niteye10 on AliExpress: Page Not Found - Aliexpress.com
The RRT0SE is a bit different from the RRT01, as it has the other modes in the ring (I don’t like it that much, I must confess). Also, I guess it doesn’t take 18350s (at least from the specs!).
I went to see some Niteye10 videos and the “clicks” on the control ring are not so nice as the smooth ring on the Jetbeam. Though, if I couldn’t find one, I’d probably take it
Once again, thanks for your comments and links! :+1:
It arrived today, my Jetbeam RRT01
I wanna thank to Tally-ho for selling and sending it to me This is indeed a very nice light with a true ramping UI, from barely visible to 600 lumens (specs)!
I put an Aspire 18350 on it and it will run beautifully! Maybe I’ll mod the emitter as the XML2 it has is CW and a more neutral or warm white would enhance it’s beauty!
Thanks for the suggestions of all members, and specially Tally-ho for the deal :+1:
Best regards :sunglasses:
I may “check in” with you if/when I intend to mod the emitter
BTW, do you remember if it has a 16 or 14 mm plate? For the diameter of the head it seems 16, but I don’t want to open and close it many times before going for the mod
The HR20 is a control ring light, but that’s about where the similarities end. The quality, lower range and ergonomics of the RRT01 is in a completely different class than the HR20. I briefly played with the V11R before gifting it, and I remember it being much nicer than the HR20 too. I appreciate HR20 for their attempt, so I bought one to show my support. Hopefully they listen to feedback and try again.
Just swapping the emitter is fairly straight forward but it is an unusual shaped MCPCB so you will need to reflow, it’s not really worth the effort filing down a Noctigon, unless you really want to
I think the Bezel will be glued too :weary:
I found some nice pictures of the light with the various bits disassembled on TLF that you might find useful :+1:
Thanks CRX for posting the pic and the link! It really is an unusual MCPCB, I don’t know if I will venture myself to open this light and eventually damage it…
Yesterday I made an accidental reflow, but damaged the plate and almost the LED, so I guess I won’t be brave enough! Or maybe I will, when I master the solder iron correctly
I bought an RRT-01 and have been enjoying the variable brightness very much. I blame MascaratumB for making me spend money… lol
I do not detect flicker with my eyes, nor with my camera
It does change brightness, using my home calibrated lightmeter, by about 10% depending which way it is facing, but If I dont move, the light holds steady regulation. I cannot detect those changes with my eyes. In fact, I probably play with the dial more than the light drifts.
note the clip is on the lower right
note change in lumens by simply rotating the whole light so clip is top left now
I dont mind a 10% change in brightness when moving the light, but Im not inclined to have a Nichia installed, as my past experience produced swings of 100% with a 219c mod in a V11R
The light I received has a very nice pocket clip, that does not interfere with the adjuster ring. However, the clip sticks to a magnet, which tells me it is not Titanium, despite the claim in the product literature.
It also has the nice Orange Peel reflector,
The low modes are just amazingly low, and it tailstands without wobbling… All good things.
The tint is predictably green, typical for Cool White Low CRI LEDs
The clip on the RRT-01 CRX got was longer, he shortened it for this pic (maybe that version was Ti?). It looks almost identical to the clip on the McGizmos, and his got a smooth reflector… different runs I suppose.
While entertaining myself googling RRT-01 I learned that it shares design similarities with the McLux McGizmo PD:
I like to think my RRT-01 is a cross between McGizmo DNA and an HDS Rotary. Except neither of those is infinitely adjustable, and the RRT-01 has lower and higher modes than its Ancestors…
You’ve both scored some fine torches. The JB/Niteye magnetic ring lights are wonderful tools.The extreme lows are useful.It’s bezel circumference is compatible with a couple of manufacturers filter adapters. The color filters are good fun. I wish JetBeam would have continued the evolution of this design.
My TCR1, carried since 2012, only mods are a 4K emitter and a waterproof, GITD, tape disc in the lanyard recess.
Jon, great improvised cash stash.
Yes, my TCR1 has the first run smooth reflector. The long clip is attracted to a magnet The Niteye reflectors fit , as expected , perfectly. Here is the TCR1 with a reflector from a Niteye Eye 12.
I was introduced to the JetBeam by a friend of mine in our local astronomy club. Found BLF shortly thereafter.
BLF member “Firelight2” posted excellent disassembly instructions in this thread: control ring lube?
So,a belated and sincere thanks to Firelight2. I’ve been able to resurrect a couple of these that had horrendous ring operation thanks to that info.
My preferred , at work , method of carrying the TCR1. The paracord pocket clip keeps the factory clip from scratching surfaces.
Kindle, thanks. Still in use, 3 decades on, rings and all. Under its ringy, dim glow many a item has been fixed and, most importantly,many a bedtime story was read to my children.
fwiw, I made a video of my RRT-01, it definitely has flicker that my phone can see, although I can barely tell with my naked eye
Jetbeam RRT-01 flicker video
Thanks, I’m highly aware of flicker and PWM, especially in my peripheral vision. I can see it everywhere, in LED christmas lighting, screens, etc,etc…. even some of my high dollar test equipment displays. Can’t say I’m “sensitive” to it though. I’m a task oriented person. Flashes, rings, hues, tones, beeps,buzzes and dings and other miniscule observations rarely interfere with my ability to get things done. Also, being a lad of the late 70’s and early 80’s , I’ve got some most excellent memories that are strobe laden. :heart_eyes: :innocent:
Yes, flicker from car taillights is another area of PulsePollution, and yes, many lights have flicker that can be photographed but is not necessarily noticeable by the naked eye.
I am not in any way trying to criticize your choice of light, in fact, I want one like yours
Taking photos of flicker and PWM is a personal interest test that I apply to all my lights. It is not my intention to judge, just inform.
Lol! Great scene! We ARE all in this together! And, no, didnt take it that way at all!!
Like you, preference is generally for little fluctuations as possible. My favorite work lighting source is still a mains driven, rough duty, Hi CRI, led lamp.
Most of my pocket lights are compromise situations, I think like many view their everyday carry items. Nothing wrong with looking for perfection.
Keep a eye out on E (vil)bay, there was a somewhat recent(last year) auction that sold a like new, TCR1 for under $95.00 USD
Jon_slider, so did you swap emitter in your RRT-01 and V11R before? Which one do you like better? I would like to buy an variable brightness rotary light and mod it with a hi cri emitter.
