Smallest 18350 light?
57 posts / 0 new
sac02
sac02's picture
Last seen: 3 days 7 hours ago
Super small lights like the Olight S-mini or new Klarus Mi1C are nice to have sometimes. But the new Aspire 1100mAh 18350 really makes me want an 18350 mini-light, to take advantage of the Aspire battery’s excellent capacity and high-drain capability.
Are there any “mini” 18350 lights on the market?
Yes, I’m aware you can put an 18350 tube on an S2 or a D4, but those lights still aren’t designed around being the smallest light possible.
EDIT:
Options mentioned so far in this thread:
18350 Format Light Length Head dia (mm) Body dia (mm) Weight (g) Approx Price
Armytec Partner C1 V2 88 25 25 55 ~$40
Astrolux E01 74 24 24 60 $16
Astrolux S1, Convoy S2, BLF A6 84.3 24 24 61 ~$15
BTU Titanium 64 24 24 45 $50, NLA
Eagletac DX3B mini 82 22 22 50 $45
Emisar D4 w/ 18350 tube 63.3 28.2 24 66.8 (18650 tube) $45
Jetbeam E20R 76 26 23 66.5 $58
Jetbeam EC-R16 71 26 22 46 ~$40
Lux-RC Minion 45-49 22 (est) 22 (est) 42 $400
MecArmy PT16 67.5 30 22.5 52 ~$50
Nitecore MT10C 91.4 25 25 56 ~$50
Nitecore EC11 75 25 25 45 ~$60
SS35-1 (sold by Neal) 63 27 27 100 $30
Sunwayman T16R * 59 26 24 31 $55
Sunwayman C13R 78 32 25 78 $42
Thrunite Neutron 2C ? 25 25 86 $50
(16340 reference) Olight S-mini Ti 54.5 21 21 31.5 $70
(16340 reference) Klarus Mi1C 54.5 20.5 19.8 27 $30
Edited by: sac02 on 10/11/2018 - 16:28
Pete7874
Pete7874's picture
Last seen: 40 min 2 sec ago
Yeah, I’m still looking for one… not just small in terms of physical dimensions, but also weight.
Here’s a recent thread I started. You might find some suggestions there:
http://budgetlightforum.com/node/56515
Tyzmon
As far as I‘ve heard the new Jetbeam E20R should also fit 18350 cells, but I haven‘t checked that myself. Additionally it has a ring for reverse polarity protection on the driver, which means it might not be compatible with the flat top Aspire 18350.
kiriba-ru
kiriba-ru's picture
Last seen: 5 hours 22 min ago
lux-rc minion
MascaratumB
MascaratumB's picture
Last seen: 3 min 23 sec ago
Yesterday I got a Jetbeam RRT01 (similar but not equal to Niteye 10)! Takes 16340s and the Aspire 18350 fits perfectly on it Big Smile
No click switch; this control ring is vey good indeed, and the range of luminosity is awesome!
You can also find some suggestions here: http://budgetlightforum.com/node/22149
The other 18350 lights I have are the 3 (and another 1 on the way) Convoy S2+ with short tubes!
More:
- BLF A6
- Astrolux S1
- Astrolux S41 and S42
- Manker E14 and E14II
- Jaxman E2L
- ThruNite Neutron 2C V3
- Nitecore MT10C (I will have one someday Facepalm )
But, as you said, almost all are “shrinkble” lights! Not designed “on purpose” to be 18350s… Flat Stare
EDIT 1: Astrolux E01 ; MecArmy PT16 ; BTU Titanium
EDIT 2: SS15 (sold by Neal)
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 /// BLITZWOLF: BW-ET1 /// DQG AA Slim Ti /// HC-LIGHTS SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 /// KLARUS: XT1C
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses:1 / 2 /// Others: Biscotti 3 & 1*7135 / Triple TIR & XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
kiriba-ru
kiriba-ru's picture
Ok, more budget solution this time.
I have some copper tubes bored to 19mm (six on the left). Dont know what to do with them, I wanted to giveaway them but cant afford it right now. I think scrap material in this box can be used to make custom “smallest” flashlight.
2017_10_25_17_14_32
CRX
CRX's picture
Last seen: 42 min 36 sec ago
Copper tube triple XP-G2 18350 reverse clicky Smile
sac02
sac02's picture
kiriba-ru wrote:
lux-rc minion
I was thinking, “maybe…” …until I saw the price, haha.
sac02
sac02's picture
Got a link to a more detailed build thread?
CRX
CRX's picture
It’s the copper core to the Cu & Alu mule I made, not really a descriptive build thread but slightly more information here
Tjohn
Tjohn's picture
Last seen: 2 days 9 hours ago
The MecArmy PT18 Triple (V.3 only) like Illum. Supply sells can use non-protected 18350 cells.
Measuring 2.64 inches, it is well under 80 grams with the Aspire 1100 mah.
It has a built-in charger, if there is no other easy alternative.
Pete7874
Pete7874's picture
Tjohn wrote:
The MecArmy PT18 Triple (V.2 & V.3 only, not V.1) can use non-protected 18350 cells.
PT18 uses an 18650 cell.
Maybe you meant PT16?
Tjohn
Tjohn's picture
Maybe you meant PT16?????
Illumination Supply has V.3
You can see 18350 included in the specs.
Pete7874
Pete7874's picture
Tjohn wrote:
Illumination Supply has V.3 You can see 18350 included in the specs.
It is PT16 that accepts an 18350 cell, not PT18.
Tjohn
Tjohn's picture
^ PT18 uses an 18650 cell.
You can see 18350 included in the PT16 specs.
All the first (V.1) PTs had the horrible CooYoo/Blackwater SR71 UI.
Illum. helped them change to V2, still missing a Yobai mode.
V.3 is PT16 only, refering to the longer, wider tube.
I have one, believe me the combo is great, even better after an emitter swap.
Tjohn
Tjohn's picture
The PT16 takes 1 18350 or 16340
The PT18 takes 2 × 18350 or 1 18650
All small PTs (10,14,16,18) will accept each other’s heads, they all go to 8.4 volts, and seem to use the same driver, along with the CooYoo and Blackwater SR71, also made by the parent company Altun.
Pete7874
Pete7874's picture
OK, that’s better, but the OP is looking for the smallest 18350 light, so it’s unlikely that he’s interested in something like PT18 that requires multiple 18350 cells.
This is what you wrote earlier:
And that’s not correct. What you’ve described here is PT16, not PT18.
That’s all I was saying. Smile
Carry on…
BTW, the PT16 is really nice, actually, apart from the price. I just wish it had a clip. Smile
Tjohn
Tjohn's picture
A clip….?
Interesting you should mention….
finally found one.
The Nitecore MH10 works well, $5.95 at the Nitecore store.
  • it helps to lift the tail of the clip when turning the tailcap,
    be care if trying to bend the clip to reform it, the metal may be too brittle to stand much force without heating first, and too much heat could cause loss of spring tension.
    It works on a cap brim, but will not deep throat…..
  • an added benefit of the clip …
    It makes it a LOT easier to find the switch
Pete7874
Pete7874's picture
Thanks. This does not look very secure. Smile
Tjohn
Tjohn's picture
It is almost too tight.
The spring tension makes it tilt a bit in the photo.
sac02
sac02's picture
I’m thinking that the reason for the lack of truly “small” 18350 lights is:
If a manufacturer wants to build a small light that has minimum size and weight as a design goal, then they are incredibly likely to use the smaller and more common CR123/16340 battery format. The 18350 battery being close to the same size but slightly bigger, gets ignored. Sad
sac02
sac02's picture
Just stumbled across Nitecore EC11 and added it to the list.
Pete7874
Pete7874's picture
Nice find.
The clip looks reversible, although it would stick out if placed the opposite way.
Surprised it only lasts 45 min on 300 lm mode. Hopefully it would last longer when using the Aspire cell.
MascaratumB
You can also add the Sunwayman C13R and the Sunwayman T16R!
Not my favourites in terms of functioning, but the both take 18350s!
EDIT : Another one Jetbeam/Niteye EC-R16 Wink
GIVEAWAY: 1
sac02
sac02's picture
Can you personally confirm the Sunwayman T16R takes 18350? I cannot find any documentation that says so, everything I see says 1×16340/CR123. If so, it is pretty small. Unfortunately 380Lm is not real competitive with most others in the class.
Pete7874
Pete7874's picture
According to this post from Sunwayman, it does support 18350:
http://www.candlepowerforums.com/vb/showthread.php?427370-SUNWAYMAN-T16R-Cu-Limited-Elegant-Copper-Edition-380-Lumens-Keychain-Flashlight&p=5019835&viewfull=1#post5019835
MascaratumB
Pete7874 wrote:
According to this post from Sunwayman, it does support 18350: http://www.candlepowerforums.com/vb/showthread.php?427370-SUNWAYMAN-T16R-Cu-Limited-Elegant-Copper-Edition-380-Lumens-Keychain-Flashlight&p=5019835&viewfull=1#post5019835
I’ve seen it here Wink
https://www.youtube.com/watch?v=qXiJOF6u3SU
GIVEAWAY: 1
ssschen
ssschen's picture
Last seen: 6 days 7 hours ago
I don’t have any 18350 flashlights myself, but just curious if 16340 and 18350 cells are similar or perhaps identical? I can’t help but noticed there are several posts indicating some flashlights will take 16340 or 18350 cells?
southland
southland's picture
Last seen: 2 weeks 1 day ago
Close but not the same, 16mm vs 18mm, 340mm vs 350mm. Most 16340 will not take a 18350 but some will.
MascaratumB
Some 16340s are longer than the 18350, though! I received a Wuben 16340, protected, that is longer than the Aspire 18350 unprotected.
It is not larger,though!
GIVEAWAY: 1
jon_slider
jon_slider's picture
Last seen: 1 hour 11 min ago
ssschen wrote:
16340 and 18350 cells are similar…?
18350 is fatter and weighs 3 grams more than 16340
18350 won’t fit my 16340 Olight S Mini:
the 18350 is not protected, it fits the PT16. A protected 18350 does not fit, too long. There is no built in low voltage protection in the PT16. I consider Protection built into the cell important if the light has no built in Low Voltage Protection and is not user monitored for Low Voltage. There is no Low Voltage indicator built into the PT16.
The transparent carrier fits only 16340/CR123
the black battery carrier fits both 16340 and 18350 (it is 1/2” shorter and narrower than a film cannister).
The PT16 has built in USB charging and will charge either 16340 or 18350, but don’t make the mistake of trying to charge a non rechargeable CR123.
I really like the new USB chargeable 16340 Protected cells sold by Olight, Fenix, and Klarus (all from the same factory, just different labels)
fwiw, the PT18 uses 18650, the heads are interchangeable with the PT16. The 18650 PT18 is also compatible with two 18350.
beamshot, the v11r is modified to 3000k 219c 90+CRI, the PT18 is modified to 4000k 219b 90+CRI, the PT16 is shown with stock 6000k XP-G2 70CRI
