Yes will do
Thanks for saying it is not the first, makes me add “2nd” and such for better overview (it is impossible to remember all on all the lists )
Please add me on the list for 1 FW3A.
Miller, my first is 158 and my second is 488 if you want to put a “2nd” after it.
Please put me down for 1 of these amazing lights! :)
Many thanks,
-Ben
Could you please add me to the list for one?
Will update listlater, ha and of course Peabody will do that too!
If the list is still open then sign me up for 1
The list should be open for a few months at least. This is definetly a 2018 light.
Yes welcome and will update list later!
Could you add to tge list please.
It seems that my post from May never made it. Please sign me up for two.
Oops, yes will update and correct list later, today.
EDIT MARK and lis updated
Here’s a triple XP-G3 Wuben light with the AR lens removed. Supposedly 90 CRI. Not bad if you ask me, as long as Lumintop doesn’t put AR glass on it. Looks quite nice outdoors.
Daylight/XP-G3 Wuben
What I’m missing in the OP are driver details. Is there already a choice made except that it’ll run NarsilM?
The driver is a FET+N+1 design, so it should have regulated output up to around 3 amps, IIRC, and the ability to go much higher than that for turbo modes. Output will mostly be limited by ability to dissipate heat.
The driver itself is custom-designed for this light.
Yes last details are put on paper for LT to make it and create the first prototype
The double tube for the e switch in the tail is unique and that alone requires custom design.
Then it is ready for TK and others to play with software to use the FW3A leds as receiving light flashes from a screen to allow programming of the driver without opening (only the hardware is in place and TK made a testsl setup to prove it can work, this needs a tremendous amount of work but if that work is put into it the hyis ready. (And it is logical new projects take this into account as well))
Yes Robert high CRI would be nice for this lamp.
Do you know the colour temperature?
Wuben doesn’t say what the color temp is. It looks to me around 5500 or so. Maybe a little more.
Please add me to the list. Thank you.
Welcome to BLF!
Will do!
