Nichia 219B and 219C, which you can find in lights like Emisar D4 and Astrolux MF-01.
Neutral White - Nichia 219CT 90CRI, 5000K
4000K, which i consider to be Neutral.
I would agree with that.
I’ve found. (With MY old eyes)
That Neutral 4000 to 5500, is better for looking AT things within sensible and closer radii.
Long Distance. “spot” type range\ usage.(5600 to 7000)
I find the white seems to give me sharper definition t’ween items in the beam
Easier for me to define them…
3 to 4000 is nah. to me.
But there again. Good days. Bad days. they vary.
That S-R5 I find the most comfortable lamp to hold in hand in over 60 yrs of holding the things.
Side sw in leiu of tail. with a short zoom.
It’d be perfect.
How about a modder sorting out one.
With XP-L-hi, and 7135 x 6 or 8 driver.
Running it on mid or Hi.
It wouldn’t get hot? with enough power in beam for normal work
and a Turbo for longer shots.
with good battery life.
Possible??. Wife will buy for anniversary for me.
or are there others of that config.
With hand comfort to match?.
My Option is missing
I’d chose the one with the highest CRI value
I use cold tints at work (not quite blue but close) and warmer tints off the clock.
Yes, I also would prefer high CRI
then I also would pick 4000-5700K CCT for focused activities, 3000-4500K CCT for everyday usage, and I would pick 1300-2200K for night time activities if night vision preserving is a requirement
(I know, monochrome red maybe does better in this regard, but it is monochrome, and it is sometimes difficult to recognize things just based on red light)
Unfortunately I haven’t seen anything except E27 LED corn bulbs on BG or GB with this latter CCT. However, I remember, Cree has 2200K CCT in their XP-E2 lineup.
I have a light bulb which does 2200K, 3000K, and 5000K. Just flip the switch off/on to change modes.
It’s getting slighly more common; hopefully it’ll be more of a thing in another few years.
Definitely CRI over tint here. I use my lights to illuminate objects other than white walls. I have lights in 4000K, 4500K, 5000K and 5600K that I’m very satisfied with, all over 90 CRI. I’ll be adding one at 3000K soon.
If I had to pick one favorite, it would be 5000K, which is most similar to the midday sun.
4500K - 90CRI
5000K - 90CRI
what are the LEDs?
I find it strange how rarely true warms are offered, especially since it seems to be favored over the CW end (so far over double) by a lot here.
For 4500K, they’re Nichia 144A and Nichia 219B. For 5000K, they’re Nichia 219C and Nichia 219B.
There’s no 5000-5700K option. No blueish tint whatsoever, lovely creamy white light.
+1
Many reasons, production volumes may be the most prominent. Most leds are made from a single monochromatic light source, usually some blue though Yuji International is venturing into violet dies with its VTC series for ultra high fidelity colour rendering. The violet hue you see on smartphones, tablets and other LCD screens isn't violet but just a pale mimic. Now add the current state of development in led lighting (still sucks) plus emitter price into the equation and the carelesness of most folks in this regard, and you can now guess why crap white plus crap rendering index is most common.
Cheers ^:)
Depends on the use. For illuminating objects (for photography) I prefer 5000k neutral, but also like to contrast between warm and cool white (the combination of warm and cool can be quite beautiful). For illuminating light painting tools, I default with 6500k, but sometimes also use anything between warm and cool. For throwers (wanting the see the beam in the photo) I’ll use cool white.
4000-5000K neutral white for me.
Cold, Warm or Neutral? … I’d choose Neutral.
- Cold (6000K+) - long range and looks decent indoors but looks hideous outdoors. Tends to be perceived as being brighter than it is, making cold tints one of the better tints for wowing your friends with your light.
- Warm (3000K) - looks great outdoors especially in nature, but makes everything look orange indoors.
- Neutral (4000-5000K) - good enough for both indoors and outdoors. Best compromise of tint choices. For an EDC light meant to be used anywhere, in my opinion neutral is the best choice.
I’m not a huge fan of high CRI. It’s nice to have, but from my experience other factors are MUCH more noticeable than CRI, in this order:
- Tint - most important factor for me. If the tint sucks, I’m not going to like the light no matter what else it does.
- Total output (high or low lumens / throw). Lumens are nice. Why carry around a 200 lumen light when you could have a 1000 lumen light the same size?
- Does it make everything look greenish? For CREE emitters you want A and D tints. C tint looks slightly green.
- CRI - this one is subtle. Good CRI helps especially for artwork / photography, but for most lights I find CRI mostly unnoticeable. Unless I actually hold up a high CRI light side-by-side with a lower CRI light the difference is almost unnoticeable.
So CRI is nice, but I’d definitely take a 4500K 80-CRI light over a 6000K 100 CRI any day.
