Wild guess: Zoom head?
No.
Im not against if this lottery will take longer than I expexted (most future projects are paused cause small demand for stocked parts), so I dont give tips that can make guess easy.
I just want to say that chances will raise if you will use collective brain. All interested supposes mentioned in thread went this way. Amount of information that was already given is more than enough to make right conclutions.
Is it a replacement tail end for a light so that the light can be positioned to tail stand?
You forgot extra ring.
I’m guessing its a drop in. The area for the optic has yet to be machined out. It would be useful to swap assembled pills quickly.
Change my mind about it being a drop-in since ElecticJelly, already guess that AND because it’s AL rather than CU.
I say replacement bezel head, before fins and cutting in two parts for front lens holder.
Ordered an X6 cu spacer, plus Ledil Cute-3SS TIR - and I'm absolutely wrapped with them. I finally got around to fitting the spacer on the weekend. A little bit of finish sanding (as is stated in the description), and the spacer slides in so neatly, it's airtight. Really happy with it - great machining, great tolerances. The packaging was also excellent (arrived in a little plastic box with each part wrapped in foam).
I will be back for more!
Got a custom triple kit for my Convoy X3, it just fits perfectly. Will use a cute-3ss with it. I haven’t modded my light completely, just test fitted the parts. The LEDs still need to arrive, so it will take a little longer until I mod the light and take some pictures.
Very common words.
I had to say that finished design is not so simple (samples are made with manually controlled lathe so they are so austere), otherwise you could recognize it long time ago.
I picked up the parcel at the post office today and everything is ok.
The XHP50 now lives in my Olight R50 and I really like the tint.
Nothing to say about the XHP70’s though, as I failed at opening my X7R…
Thanks again for that great deal
Received my pill and and XHP70 a couple days ago. Ordered 10/23, shipped 10/23, got it 11/3. Came super well packaged. Got my order from mtn electronics the same day so my triple build is a go. One quick off topic question: how should the xhp70 be aligned on the sinkpad PCB?
Pill + LED:
Optics and MCPCBs from Mtnelectronics:
Pm sent for some pills, I need them pills.
Replied.
Lol, nice.
hahaha nice meme
Need your help guys.
What is optimal recess for button top 18650 mechanical protection? I mean height diffrerence between positive contact plate and plane where negative side will stop.
30Q button tops I have here from Banggood are about 67mm long measured with a ruler. Digital calipers are in the shed.
1-1.1mm a bit difficult with a 12’’ digital vernier, should be close enough?
