Could you add to tge list please.
It seems that my post from May never made it. Please sign me up for two.
Oops, yes will update and correct list later, today.
EDIT MARK and lis updated
Here’s a triple XP-G3 Wuben light with the AR lens removed. Supposedly 90 CRI. Not bad if you ask me, as long as Lumintop doesn’t put AR glass on it. Looks quite nice outdoors.
Daylight/XP-G3 Wuben
What I’m missing in the OP are driver details. Is there already a choice made except that it’ll run NarsilM?
The driver is a FET+N+1 design, so it should have regulated output up to around 3 amps, IIRC, and the ability to go much higher than that for turbo modes. Output will mostly be limited by ability to dissipate heat.
The driver itself is custom-designed for this light.
Yes last details are put on paper for LT to make it and create the first prototype
The double tube for the e switch in the tail is unique and that alone requires custom design.
Then it is ready for TK and others to play with software to use the FW3A leds as receiving light flashes from a screen to allow programming of the driver without opening (only the hardware is in place and TK made a testsl setup to prove it can work, this needs a tremendous amount of work but if that work is put into it the hyis ready. (And it is logical new projects take this into account as well))
Yes Robert high CRI would be nice for this lamp.
Do you know the colour temperature?
Wuben doesn’t say what the color temp is. It looks to me around 5500 or so. Maybe a little more.
Please add me to the list. Thank you.
Welcome to BLF!
Will do!
Having used my D4 and other 10+ amp pocketable lights for a while I feel the need for setting a different ramp ceiling (I’m not the first to come up with this, but now I experience the need myself). The regulated 3A is a great and logical ceiling because it is regulated and because (from own measurements on a S2+) a light this size will not self-destruct at 3A (by just).
Would two ramp groups be an option for the FW3A? One to absolute max and one exactly the same but going to 3A.
(that would be simpler and more precise for the user than a user-settable variable ramp ceiling, as has been discussed as well)
Please remove me from the list. I will buy soon an Emisar D4 and I hav too many multi led pocket rockets.
Thank you!
No need to remove yourself. Your not obligated to buy anything.
Besides, by the time the light is ready for sale, you might have changed your mind and want one again. Lol
Like with the Q8 I wanted to remove myself because I wanted the UT03 more but that stopped. So now I have a Q8 and I’m happy.
Please sign me up for one, Thank you.
Add me to the list for one please. I need a new EDC, one that is shorter that my current Convoy S2.
Thanks!
-Garry
Yes will update the list later!
Wishing that it would use a 5000K 90CRI XP-G3.
Please add another one for me. Thanks.
Does that exist? I don’t recall ever seeing it.
