Hi, newlumen,thanks for your support of the Shockli battery,wish you satisfied with it. In addition. may you share what models of flashlight can use with Shockli 26650,5500mAh battery?thanks.
welcome to discuss, in order the members can buy the right products.
Hi,Panni,we have retailer in Germany, but he carries Shockli 26650,5000mAh cells, not 5500mAh, you can ask our retailer in UK,his name is Torchythebatteryboy, and see if
he can ship to Germany. thanks.
Orbtronic could have these at very good (budget) price (flat top), but the diameter 26.60-26.70mm is problematic. So guys what do you think about diameter?
Are these better then the Liitokala 26650-55A? (Not the 26650-50A)
I think those I have at home (not home right now so can’t check) charged to around 5700mAh at 1A nor-test on my LiitoKala Lii-500 charger.
I think it’s rated for 20A continues and 30A pulse.
Checking the aliexpress store reviews where I bought it and the most one reviewer got was 5922mAh on the LiitoKala Lii-500 charger with 1A nor-test but then the charger showed 4.22V…
Can’t give you a link to it… seems weird. I can’t find the product when using the browser but if I search for “26650-55A” on the app and filter on “number of orders” it’s right there on the top with 159 orders right at this point.
Depends what “better” means to you.
Assuming the 55A is just a higher capacity version of the 50A, then it will have a larger voltage drop and lower capacity under high load than the Shockly, even though it has a few hundred mAh higher capacity.
You can compare the Shockly to the 50A here: Battery test-review 26650 comparator
Personally I would go with higher discharge voltage and longer runtime under load instead of a few hundred mAh more capacity.
But pretty sure the 55A is 20A continues and 30A pulse.
And the shockli amp rating is the same.
Shockli mAh rating is 5500mAh and I’m pretty sure the –55 at the end of the LiitoKala’s mean 5500mAh.
So the ratings should be the same for both cells?
I don’t know what the shockli cell cost but I think the LiitoKala’s 26650-55A is pretty cheap so I just wondering if someone knows if the shockli cell is superior or not, if I should go searching for these.
The amp rating is not what matters.
What matters is the real-world discharge tests under load.
You can see in the tests I linked how the 50A has a much larger voltage drop under load, causing it to have less capacity than under 1A load.
The 55A is just 500mAh higher capacity, which will change the voltage drop characteristics very little, it’s mostly just a capacity bump.
The liitokala 50A actually has a slightly lower IR than the shockli 5500mAh cell, but the shockli holds a higher voltage for most of the discharge mostly because of its higher capacity.
The liitokala 55A cell identity is unknown until it has been measured by a reliable source. I think I read someone on this forum tested it at ~5600mAh. It could be the power long battery INR26650-55A, or it could be something else.
This is not true, the capacity difference is only 10%, but if you compare the 10A 50A and 15A Shockli discharge rates you will see that the shockli maintains almost the same voltage as the 50A, while proving 2,72C discharge compared to the 2C discharge of the 50A.
10% capacity increase but 36% C rate increase.
On top of that, it gives almost 1000mAh more capacity at 15A.
You will notice that the Shockli gives 5.75Ah at both 1A and 15A while the 50A actually decreases from 5.2 to 4.8Ah when going from 1A to 15A discharge.
This is indication of a much higher quality cell with better current handling characteristics for the Shockli.
It probably is a killer price for the same PLB INR26650-55A cell, Enderman. Don't you wanted to build some big battery pack? Of course, it may be a risk before your eyes.
There's just one test made of this cell, and it may well be a bit of a cherry pick. Just maybe…I can also understand Shockli may have asked and paid PLB for a cherry pick bin shipment. LoL! :-D
Nah man, stick with the Shockli, no guarantee such cell is the 55A, I only see blue and black 50A wraps among the product reviews. Wish AE sellers were more clear with their product ads.
Mmm… maybe you should order a pack, to later file a claim/dispute because your cells have LiitoKala branded black wraps. If you win you would at least get some discount. I want my red Dolidada wraps, you @#$%! :-D
