Hmm, a ramp with a factory-set limit which isnāt user-configurable? Hadnāt thought about that. What do people think?
I was originally thinking maybe three operating modes:
User-configurable smooth ramp
User-configurable stepped ramp
A smooth-ramp āmuggle modeā
That last one would perhaps go from 10 lm to 3 Amps. Perhaps it could still be configurable, but only when muggle mode isnāt active? Even 3 Amps could still be a bit much for sustained use. In any case, itād be kind of like momentary mode, where itās a one-way trip and requires a special action to exit. Probably cutting power or maybe some sort of click sequence.
The regular ramp modes would have safe factory defaults, but still have access to turbo and the ability to change the ceiling and floor if desired.
If a factory-hardcoded one is desired, exactly like the regular ramp but with parameters set in stone, I think itād be relatively easy to add. Much easier than a separate muggle modeā¦ but it would still have access to everything else too, like blinkies. Is that a thing people want?
Personally Iād be interested in something like the second option (donāt have a ton of use for a muggle mode), something like an āedcā mode that still has a moonlight, but only goes through the regulated ramp. That way, I could avoid starting any fires in my pants during daily carry, but still change to the retina searing fun mode on occasion.
Something like this you are wishing. Its a mode for someone who has no experiences with high-power flashlights.
The name comes from harry potter. A muggle is a non magican or normal person.
FWIW, the default settings will probably be for a ramp ceiling of 3A,with direct-drive turbo accessible by a double click. But it should be configurable to raise or lower the ceiling if desired. And the floor too, for that matter.
I donāt know if muggle mode is a thing people want or not, or how exactly it should work. Could be a ramp with safe limits, could be a simple low/med/high, not sure which is more muggle-friendly.
