Is anyone planning to strap it to their bike and use bike strobe? Probably not.
I have zero use for any of the blinkies.
Since NarsilM, as a UI, can be used across many different sized lights, it’s just easier to keep them in the software, than remove them. I guess it’s better to have it and not need it, then to need it and not have it.
Ps, why was SOS not included? Does it take up too much space?
A plausible scenario is while you are doing a search and rescue operation on a mountain you get injured or lost and need to signal that you need help!! With the beam and throw it will make a great light for signaling searching aircraft (and people in the valley) as to your location and that you need assistance in case your radio is dead or out of range!
A momentary on button might have also been considered for the GT for search and rescue and signaling purposes….just a thought for a light designed for search and rescue! I like that my Acebeam K70 has a momentary on it is very useful so you can quickly look in a direction without having to go through the UI just to take a quick look in a direction…. plus signaling is now a viable option especially with the distance you could signal over in Morse Code…… just some thoughts; still thus far the GT looks like an awesome light for search and rescue!
Yep, Prototype 2 showed up while I was at work yesterday (turned out it was a whole light and not just the reflector which is great!). I only had a few minutes to look at it this morning before heading back out to work but first impressions are it is a significant improvement.
The reflector is MUCH better.
The kurling is fantastic as well, perfect combo of style, grip and subtlety. A+ on that.
The polarity protection of the cells is also great. I like how they ended up doing it, makes it easier to insert the cells, A+ once again.
The new carriers are nice as well, all metal construction this time, double springs and should have lower resistance but obviously didn’t have time to dig further in a few minutes.
It also has an indicator LED in the switch now!
I will try to make time tonight if I don’t get home too late to look at it closer and get some pictures.
It is still at least a few weeks until it is ready to ship. So up to you when you want to order the batteries.
I think the lumintop is going to try to get some Samsung 35E or another good cells to ship with the light but they have not confirmed one way or the other yet and no clue on pricing. So might be worthwhile to wait and see what lumintop comes up with to ship with the light.
They sent along what we hope will be the final XHP35 separately as they got them last minute. I will reflow it and install it later to see what it looks like. They sent 2 of the NW LED’s as well, so the other one I can put on the sphere to see exactly what we are dealing with.
