HaikeLite HT35 XHP35 HD CW/NW 2300LM 3Modes Zoomable LED Flashlight 1000M
using coupon code 11HT35 price drops from $65 to $39.00
Code took price down to $79.57
petemer - so the MT03 II deal is only as good as GearBest at $79? Is it supposed to be $65.40? I'll order one or two at $65... Let us know.
Astrolux S42 4xNichia 219C/XP-G2/XP-G3 A6 2023LM Rechargeable Mini LED Flashlight
It’s now in fash sale for only $24.95
Offer expires in 2 days.
For use with high current 18650 cells to achieve full light potential additional 18650 body tube is available here: Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.80 |
$2.76 |
$2.73 |
$2.70 |
$2.63 |
the details I got fom BG said that the code should take price down to $65.40 and it’s valid for 11.11 promo festival.
I asked them to check the price and I will let you know here when I get the answer.
Pete.
Astrolux MH10 XPL HI 18650 1000LM USB Rechargeable Outdooors LED Flashlight
It’s now in flash sale for only $21.69 !!!
Flashlight can be directly charged via micro USB port. Holster, standard micro USB cable and spare orings are included in the package.
Short tube available here: 1pc Astrolux MH10 Flashlight 18350/16340 Battery Tube for $2.59.
Astrolux S41 4x Nichia 219B/XP-G3 A6 1600Lumens Mini LED Flashlight is right now for only $23.00.
Offer ends in 3 days and 4 hours
Additional 18650 body tube to achieve light full potential with high current 18650 cells is available here(now in black, blue and red):
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.80 |
$2.76 |
$2.73 |
$2.70 |
$2.63 |
New Fitorch coupon codes with even better discounts!
Only valid for 11.11 promo festival.
Model | Coupon code | Original Price | Price with coupon | Discount | Link |
Fitorch MR35 | 11MR35 | $76.25 | $39.65 | 48.00% | Fitorch MR35 XP-L2 1200Lumens 5 light colors Rechargeable Portable UV LED Flashlight |
Fitorch P20R | 11P20R | $54.99 | $29.69 | 46.00% | Fitorch P20R XP-L2 1180Lumens Rechargeable Tactical Mini LED Flashlight |
Fitorch P26R | 11P26R | $103.29 | $49.58 | 52.00% | Fitorch P26R XHP70 3600Lumens FCD Rechargeable Portable LED Flashlight |
Fitorch ER16 | 11ER16 | $50.99 | $27.59 | 46.00% | Fitorch ER16 XP-L2 1000Lumens Magnetic Tail Rechargeable Mini LED Flashlight |
Special 20% off discount for all flashlights using coupon code 4fdb18
Valid: November 11-13
Coupon will not work if the flashlight is already in other promotion or flash sale(promo tag is visible in cart).
Ok, it's still only getting the $79 price.
Astrolux S42S Stainless Steel 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight
It’s now in flash sale for only $29.99
Offer expires on Novenber 12.
To get maximum light output and runtime from this light you should use high drain 18650 battery with additional tube available here:
Astrolux S41S/S42S Flashlight 18650 Extension Tube Body Tube for $9.00 or with using BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$7.65 |
$7.56 |
$7.47 |
$7.38 |
$7.20 |
BLF A6 XPL 1600Lumens 7/4modes EDC LED Flashlight 18650
It’s now in promotion for $18.99.
Offer expires on November 12.
All tints available: cool (1A), neutral (3D) and warm (5A).
LUMINTOP Worm 4.0 XP-G2 110LM Mini LED Keychain Flashlight
It’s now in promotion for $10.99
4PCS Samsung INR18650-30Q 3000mAh Unprotected Button Top 18650 Battery
It’s in promotion for $17.99
Astrolux C8 XP-L HI 1300Lumens 7/4modes A6 Driver Tactical EDC LED Flashlight 18650
It’s now in preorder for $19.99.
This is tried design based on prevalent C8 host with XP-L HI LED (1A and 3B tints available) and BLF A6 FET + 1xAMC driver.
This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm, spring bypass may be needed).
And of course same great UI as BLF A6 :+1:
Astrolux K01 CU XP-L 7/4modes 1400LM Tactical EDC LED Flashlight 14500
It’s now in promotion for $27.95
100% copper built, 1A, 3D, 5A tints available up to 1300-1400lm (spring bypass may be required), A17DD-L FET+1xAMC driver (same as BLF A6/Astrolux S1).
Lumintop Prince Brass XM-L2(U2) 18650 Waterproof EDC LED Flashlight
It’s now in promotion for $29.99 ($78.90)
Offer expires on Novemer 12th.
Lumintop Prince Copper XM-L2(U2) 1000LM 18650 Waterproof EDC LED Flashlight
It’s now in promotion for $31.99 ($79.95)
Eachine EV100 720*540 5.8G 72CH FPV Goggles With Dual Antennas Fan 7.4V 1000mAh Battery
It’s now in promotion for $96.99 ($349.99)
White and Black color versions available.
Offer expires in 1 day 9 hours.
EKEN H9R Sports Action Camera 4K Ultra HD 2.4G Remote WiFi 170 Degree Wide Angle
This version is equipped with mini remote control. Multiple colors available.
It’s now in flash sale for only $37.99
Offer valid until November 30, but stock is limited so color availability may dwindle.
