Exploding flashlight kills man
36 posts / 0 new
mortuus
mortuus's picture
Last seen: 6 hours 3 min ago
...where Frugal meets with Flashlight!
AgentSteel
AgentSteel's picture
Last seen: 10 hours 56 min ago
Reminder : don’t put li-ion powered flashlight in mouth Shocked
Quidquid latine dictum sit, altum sonatur
DB Custom
DB Custom's picture
Last seen: 3 hours 20 min ago
Goodness. From that article it would appear he leaned in over the radiator or from the side and maybe grounded out the positive terminal of the car’s battery with the flashlight, causing the light to explode. His face,neck and upper body would have been exposed to the explosion. Sounds like a horrible way to go…
atbglenn
atbglenn's picture
Last seen: 2 weeks 3 days ago
I do it all the time. Maybe should stop.
Jack Kellar
Jack Kellar's picture
Last seen: 2 hours 25 min ago
Very unfortunate circumstances, those.
The Miller
The Miller's picture
Last seen: 10 months 2 weeks ago
All the best for family friends and loved ones.
Does anybody understand what happened here?
FPV
FPV's picture
Last seen: 1 week 13 hours ago
poor guy. I lean into the engine bay with my flashlight all the time, thank god my battery is in the trunk and there are no exposed contacts. Still, need to wear headlamp at all times now.
RIP
EasyB
Last seen: 1 hour 25 min ago
Wow pretty disturbing. It’s really not clear what happened. If the flashlight shorted the car battery like Dale supposed the flashlight might heat up enough to send the cells into thermal runaway, but this seems unlikely. I wonder if it was a pre existing condition with the light (bad CR123 cells in series or something) or if the article was wrong and it was unrelated to the light (something in the car blew up and they thought it was the flashlight).
Jack Kellar
You know, that’s a possibility…
FreeMagenta
Last seen: 5 months 6 days ago
Sigh… poor man…
Well, that’s the reason I don’t want lithium batteries on my head.
By the way, this isn’t first time that flashlight was put in the mouth and exploded…
https://www.youtube.com/watch?v=cYrqHK5b8U0
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 7 hours 52 min ago
Every day millions if not billions of people hold lithium batteries to there faces by using there phones i dont think its such an issue if engineered well.
Al thought this is not the first case after a quick google search its happen a few times.
This is an older case with pics of the light in the article.
https://www.usatoday.com/story/news/weird/2015/01/17/exploding-flashligh...
atbglenn
atbglenn's picture
It’s a Solarforce L2T in the picture.
Looks like they where was using 2 cells? If they are the batteries to the side
DB Custom
DB Custom's picture
The article doesn’t say anything about the man putting the light in his mouth, nor does it say anything about whether or not it was a Li-ion flashlight. It was said that when he leaned down into the engine compartment his flashlight exploded. So I was assuming the flashlight grounded the positive battery terminal.
DB Custom
DB Custom's picture
Sorry, my bad, it does say it exploded in his mouth.
atbglenn
atbglenn's picture
Looks like it.
Water ingress from saliva causes a short?
FreeMagenta
Phones aren’t good for holding the pressure – in most cases I can throw it away if I feel phone burning. Also, typically phones are held far enough from most sensitive parts (eyes, mouth…)
Streamer
Streamer's picture
Last seen: 9 hours 24 min ago
Those batteries look to have been 123A type IN SERIES….danger Will Robinson ! Those have been indicated as potentially dangerous before.
And what is the possibility he could have had RCR123’s installed???? And In Series ! Shocked
Not enough info.
stephenk
stephenk's picture
Last seen: 1 week 3 days ago
Yep, there are these things called headlamps!
korpzgrinda
korpzgrinda's picture
Last seen: 2 months 6 days ago
Location: Eastern Woodlands in the Wilderness of North America
Headlamps, sure… perhaps an explosion near the frontal lobe does less damage.
Odd coincidence that the OP’s name has something to do with death and mortality…
old4570
Last seen: 4 days 1 hour ago
12 volt through a 3v or 4.2v battery , yep !
Thats pretty much how they make Li-ion / LIPO go boom ..
From serious over volting ..
Check out youtube , I saw one where the guy tried and tried to make lipo fire and failed … Only succeeding when seriously over volting the battery .. Reverse polarity short is ?? , over volting is pretty much a sure thing . ( A lot of extra volts – not just a little ) The boom ! Lipo fire can be nothing , or it can be magic smoke , or flame and smoke , or a small bang and flame or it can be a pipe bomb .. It’s just the luck of the draw , and if 12 volts got jammed through those batteries , ?? it could have been a pipe bomb . ( Those nasty variables )
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
FreeMagenta
Guess the skull protects a little…. I would be concerned about eyes though.
Theodore41
Last seen: 15 hours 57 min ago
Not enough info.
Why is this please?
DENGOH
DENGOH's picture
Last seen: 2 weeks 6 days ago
Lithium batteries in series are always dangerous if one of them depleted earlier than others. It heat up very fast as i encountered this a few times for both rechargeable and non rechargeable, bad quality one will explode i guess.
cool i'll see you when you get there
Theodore41
Thank you very much.
DENGOH
DENGOH's picture
No problem. I had one time used two genuine Energizer AA lithium bought at local shop like Watson or Guardian, some how one of them depleted earlier and i suddenly felt flashlight battery tube was getting hot. I quickly switched it off and measured the voltage of them, one was like 0v. It is confirmed by my own experiences it’s not safe to give lithium batteries to common flashlight user. I think i made this mistake when i gave my family some AA flashlight thinking AA is safe. Now i give them USB rechargeable flashlight only.
dw911
Last seen: 2 weeks 1 day ago
I wonder if was the car battery exploding and the torch is unrelated or maybe the torch only caused a short or his watch or something else on or near the car battery that might have ignited the hydrogen gas.
Find it hard to see a torch that someone could fit in their mouth would have the power to kill them, but could see a large lead acid battery exploding close to someones face or head having enough power to cause serious injuries or maybe even killing them
stephenk
stephenk's picture
I don’t understand why people still use 2 CR123 instead of a single 18650?
Jack Kellar
Surefire/Streamlight conditioning?
SIGShooter
Last seen: 2 hours 24 min ago
I think most people don’t think about risks that are relatively rare and that has never happened to them. Look at all the people who buy reloads at gun shows from people they’ve never seen before who may or may not know what they’re doing. And high pressure rifle rounds that let go right next to your face can do a lot more damage than any flashlight battery that vents/etc.
