Hi bikenber73. If you receive the new version (don't know if it is available yet), you should be fine with unprotected cells. If you receive the first version (like reviewed in this thread), you will need protected to avoid frying the emitters.
It's recently came out. I've been putting it though its paces and it's sweet. It's a litte beefier and has a side switch. It's similar to the hot rods we build here, but tamed down to be safer for the masses. It's rated at 2540 lumens (IIRC), but I measured 3K at startup and 2900 at 30 seconds with the stock cell (8.8 amps at the tail). It's DD. So performance will depend on the cell. Sofirn tamed it down by using XPL emitters (high Vf), protected cell, and FW.
The heat sinking on the light is top notch. Carries the heat from the head to the tail efficiently. The whole light warms up as you use it. Very nice. I should be posting a review in the next few days.
A 30Q would probably toast the old version (one reviewed in this thread) quite handily. I'm planning to mod mine by drilling a hole through the thermal pads and emitter shelf and then pounding in a copper wire. Then I'll probably reflow in some Nichia 219C's or something.
Does your light have a side switch or a tail switch?
Just the tail switch, I read the review but decided it would be a great idea to see if I could kill it with the 30q. I have to say that it was pretty impressive with the battery that it came with for the less than one minute I used it before I said, âlets put a new battery in that is fully chargedâ! That lasted about a millisecond after I hit the power switch but was a very bright flashâŚ
Actually no discount code needed right now on Aliexpress, itâs on sale right now for 2 more days. At $35.50 itâs very close to the same price as using the coupon code on amazon, it may even be less if you use the app.
This is the lowest price Iâve seen it anywhere, I donât think there is any discount code available to make it less than that. Hereâs a link:
