I tried watching the videos, but it seems pointless for me now as my computer has some sound issues and I can’t hear anything.
By starting from scratch I meant turning the light off and ramping from moonlight up.
Okay, so your having trouble switching from ramping up to ramping down?
It has to do with timing. If you ramp up, release the button and then press and hold it again within 1.2 seconds, it will toggle and ramp the opposite direction.
If you wait more than 1.2 seconds, it will continue ramping in the same direction.
This is practically the first line of the features in the manual.
Ramping – smooth 150 level ramping, simple click&hold ramps, 1 click ON to last level, 1 click OFF, direction of ramping will toggle unless you remain at a level more than 1.2 seconds.
To ramp down, simply hold the button. It may go up or down, depending on which way you were going before. If it goes the wrong way, release the button and hold it again to ramp the other direction.
So, there is no reliable way to ramp down without sometimes ramping up first, but it doesn’t require going all the way to the end of the ramp before turning around. Just hold the button, and if it goes the wrong way, release and hold again.
Not sure, but seems like these would work well on the Batt- end: https://www.fasttech.com/products/1425/10012815/3748000, as long as the hole is wide enough to handle the top of the springs, I would think would prevent contact on the brass ring.
I still prefer the 3D printed plastic inserts, but they still need some tweaking. I know what can happen in the cold and dark, or distractions goin on when you are replacing the cells - that's can happen.
The Red "+" marked also sounds good. I've used Sharpies on cells and they still seem to rub off easy. I've dated my cells with a Sharpie, then put Kapton tape over it - that stays well, but in tight tubes the Kapton tape can get messed up, but they've held up well for the most part for me.
good, finally my second Q8 has arrived in Spain, the first I could not try it, I sent it to Antonio, and I repair it, mine is the second round, and it needs a screw, hahaha, but it works very well, Antonio I’m going to send copper screws, I was impressed as it is, and the precious dye, I have on the way the case for grenade, other 4 Q30, and the hitch of 1/4, to put a lanyard, thanks to all, and for the other gift flashlight.
This one is so good, everyone that seen it is impressed by the light and of course by the very nice firmware.
Made a order now for a second one to go inland Finland as a present.
I am sure it will do a great job there as well now when it’s just a few hour of sun/day.
With +1900 pre-orders at the moment, I would call it a huge success
Yesterday my 4 button top 30Qs finally arrived, ordered in August, showing around 3.4v it took almost 2600mAh to charge them.
My v1 Q8 finally shines as it was meant to, I cannot measure the output but it is quite impressive, lovely neutral tint, colours show well. What is particularly noticeable is that when aimed at a tree maybe 50m away, my A6 will illuminate it, but with the Q8 the details of individual leaves and branches sharpen dramatically, like the channel is being tuned in, for those who can remember rotary tuning TV (ok now I feel old).
I doubt I am getting the best though, as it never gets uncomfortably hot, and I haven’t modified or even cleaned up contacts yet.
One possible issue though, and I don’t remember anyone else reporting this, when left on full output for a minute or so, it wouldn’t turn off until ramped down a bit, but I haven’t been able to repeat this after a few attempts today. I will continue to watch out for this.
I suppose it’s possible that the heat has made timing changes and the threshold for a quick click (to turn off) has gotten shorter than what you have been doing?
On the subject of UI issues - here is one that I know is my fault, but I wanted to bring up so more people are aware of it.
I was packing up a Q8 to take to my Dad over Thanksgiving and locked it out - through the bubble wrap, in the box. Four clicks. The first click felt a little wonky, but - hey I got four blinks so it must be locked out! Right?
A few minutes later I noticed that the box was blinking. Q8 was in battery check mode, happily blinking out the cell voltage. The cells had been at four volts (or more) so with confirmation bias, I KNEW I was in the right place and didn’t pay further attention.
I don’t think this requires a change to the UI, just something to keep in mind.
When I want to lock it out, I always unscrew the head past the point the green lighted switch goes dark.
Yeah, that will increase wear between battery tube and driver ground ring in the long run. Conductive lube added to minimize that.
In my example the mechanical lockout is not reliable, at least on my V2. The thread is very tight and the ano a bit thin, I get flickering when I wind it down when replacing cells.
For my Q8 at least I would trust the soft lockout more, obviously like most lights, cell removal would be the way to go for 100% certainty.
Just made me think, does the Q8 remember soft lockout after cell change? I’ll have to try that.
Interesting. That hadn’t really occurred to me, but I always got impatient waiting for the confirmation blinks on lockout so I made it do two very quick flashes instead of four slow ones. Kinda regretting not doing the same to the D4 firmware, and moving its lockout to four clicks, because six plus four is slow enough that I’d usually rather unscrew the tailcap instead. But four plus two-quick seems okay.
Yes, a jolt, not necessarily much, will re-set the torch. Try it yourself, even a small slap on the base.
Switch LEDs will blink.
It will be back into I think lowest level of ramping, not sure what happens if it was set in modes. Nor other “soft” settings.
Mechanical lockout can work if no conductive grit in the threads. Mine, as delivered, had swarf there. After careful cleaning with old toothbrush and solvent it doesn’t, and the remaining anodisation is insulating.
Mechanical lockout is the same as momentary cell disconnection. Certain things are only remembered in battery-backed memory and will re-set to defaults. Others are stored in non-volatile memory, and will persist.
