LOVE IT :heart_eyes: I want one of these!
Love the UI as well! Having that Double Click for turbo is top for me :sunglasses:
Knowing Manker quality (from my E11) this will be a great light! Is it available yet?
Well, on this U12, if I understood correctly the diagram, with a double click the least you can do is enter the second group, that starts on Turbo. So, double click from ON or OFF goes to turbo!
I have Manker E11 and rarely entered Strobe by clicking 2 times, unless I really wanted to get strobe. Their timing is really nice on that, I admit!!
I find it much too easy to accidentally fall into the 2nd group while cycling through the 1st group, this double clic to change groups is very irritating in practice, i don’t use my Manker U11 and won’t buy another flashlight with the Maker UI because of that.
Clic and hold for 2 seconds would solve the problem.
I like the simple design. I like the battery indicator also. Should be a standard…then you dont need bat check in UI. What i dont like or understand is why programmung is taken away on the never models. And this time regulated step down…bummer. should be temp regulated.if you have the bat check in button you can estimate your usage time and run the lamp hard in cooler weather or something…
