[New Release] Mankerlight E05 II AL/Cu 1300 Lumen Highest Output Pocket EDC Flashlight in 14500/AA Class
Hello Manker,
Will a 21700 cell fit in this light?
I don’t like the UI at all, I had one manker before and every time I wanted to quickly change between modes entered in strobe mode by accident.
Well, on this U12, if I understood correctly the diagram, with a double click the least you can do is enter the second group, that starts on Turbo. So, double click from ON or OFF goes to turbo!
I have Manker E11 and rarely entered Strobe by clicking 2 times, unless I really wanted to get strobe. Their timing is really nice on that, I admit!!
I find it much too easy to accidentally fall into the 2nd group while cycling through the 1st group, this double clic to change groups is very irritating in practice, i don’t use my Manker U11 and won’t buy another flashlight with the Maker UI because of that.
Clic and hold for 2 seconds would solve the problem.
That would be a completely different light! Like an Manker E11, with the addition of USB-C charging.
Thanks! U12 is available now, you can check on www.mankerlight.com
Thanks Manker.
Will there be any discount for BLF? Or any group buy?
I like the simple design. I like the battery indicator also. Should be a standard…then you dont need bat check in UI. What i dont like or understand is why programmung is taken away on the never models. And this time regulated step down…bummer. should be temp regulated.if you have the bat check in button you can estimate your usage time and run the lamp hard in cooler weather or something…
That should be the Dragon Breath mode.
Last time i checked there is none group buy/coupon from manker
:person_facepalming: Wish there was one… with a nice price… :weary:
still prefer 18650s……
I think the discount code for the Manker E11 is UT01
any others?
will there be a brigther flooder then e14 2 that will run on 1 x 26650 maybe ?
Apparently not, since they avoided this question twice…
20700 + USB Type-C + 6V emitter, now that is some innovation :slight_smile:
But that UI will be a no-no for me, bummer :frowning:
Not being 21700 capable, the UI, the price, and only 2000lms?
Pass!
Nice light but I don’t buy without a discount code.
Manker E02 Titanium Version. Edit 20171212
Special Offer Mankerlight 3 Year Anniversary(link is external) Edition (Manker T01s) is releasing
Features
Emitter: CREE XPL HI LED (CW and NW for your choices)
Maximum 420 lumens output, power by 1x AA battery
Maximum 800 lumens output, power by 1x 14500 battery
Driver: Most efficiency constant current circuit, maximum runtime up to 300 hours
Material: Aircraft-grad 7075 aluminum body
Surface treatment: Premium Type III hard-anodized anti-abrasive finish
Clip: Titanium coated stainless steel clip
Lens: Toughened ultra-clear glass lens with anti-reflective coating
Reversible & removeable Stainless Steel Bezel
Forward Clicky Tail Switch
Dimensions: 105mm (length) x 35mm (Head diameter)
Weight: 45gram (without battery)
Accessories: o-ring *1, lanyard *1, pocket clip *1
Brightness levels & Runtime:
Powered by 1x 2500mAh AA NiMH battery
Working voltage: 0.8v-1.6v
Moonlight 0.5lm 300hrs,
Low 5lm 13hrs,
Middle 58lm 5.5hrs,
High 220lm 1.5hrs,
Turbo 420lm 1.3hrs.
Powered by 1x 3.7V 750mAh 14500 battery
Working voltage: 2.7v - 4.2v
Moonlight 7lm 90hrs,
Low 45lm 12hrs,
Middle 100lm 3.5hrs,
High 270lm 1hrs,
Turbo 800lm, 0.5hrs.
Operation:
Forward clicky tail switch,
On / Off: Click for on and off, 5 output mode in total.
Change modes: click within 0.64 second to change modes,
the light will memory your last mode if the time get over 0.64 second between two clicks.
More details please visit: http://www.mankerlight.com/mankerlight-3-year-anniversary-edition-manker...
Aliexpress: https://www.aliexpress.com/store/product/Manker-T01s-800-Lumen-CREE-XP-L-LED-Flashlight-AA-14500-Torch-With-reversible-Bezel-Mankerlight/1406554_32844293593.html
