Great News! ! BLF Q8 flashlight will be available on amazon USA soon. If you would like to order more, we have limited quantity promo codes(49% off)and the price would be the same as Group Buy: $40.
And If it is convenient for you, could you please spare a few minutes and help to share an honest review of BLF Q8 light on amazon? Here is the product link.
BLF Q8: Amazon.com
If any question, please feel free to contact.
Best Regards
ThorFire
Oh boy, phone issues and real things needed doing, to beat at night, and it all looked so peaceful (phone not getting emails, only some “update” marked things, so I did get some mails, and thought it was really not busy and was glad with that, have to do things before the real frost sets.
BUT seeing a lot of activity here, heck a new topic 312+ post about GT logo, and 416+ new posts in the GT topic, oh oh.
Here it seems better.
One things that popped out
This says a great deal about how dedicated you have been, The Miller. It’s impressive and very worthy of praise. You have gone the extra mile and continue to do so. Really. It’s rare in this day and age to see someone dedicated and helpful like you are. Your karma bank must be pretty dang full! So many people try to get by with the bare minimum but that’s not you at all. Thank you.
Has anyone found a heat conducting material that also lubricates for the threads between the head and cylinder? It could get a bit more heat out of the hot part.
I thought of heat sink transfer goo. But nothing that says it won’t dry out or turn liquid. Drying out could be a bad thing. Liquid metal bad on the not drying out side.
Copper Grease/Copper Ease/Copper Slip would have good thermal conduction I would expect, not sure of its viscosity at high temperatures but its commonly used on the back of brake pads to dampen vibration and does not seem to melt and run out, so expect it to be OK at Q8 head temps?
I think all the same arguments that applied to the pages of electrical grease discussion pretty much apply to thermal grease but even more (more because for thin layers thermal connection is affected far less than electrical), and the conclusion then was, just get a good thin grease.
If we are looking for an aftermarket tail cover, I’d like to see one with enough room inside for a charging board. I’m fine with taking the tail cover off to plug in a USB cable. Some minor mods to the tail PCB and a TP4056 board and we would be well on our way to onboard charging.
Better make a tail cover that supports magnetic charging instead, that would make charging much easier since there will be no need to unscrew the cover to plug it in.
My first thought was that this is a genius idea. Around the house and even in the car it would be a quick way to charge it up and would definitely be quicker and cause less wear. My second thought was that battery banks have USB, but not inductive ports. Which means that you would need to carry a wireless charger as well if you were taking this camping for instance. My third thought is that the obvious answer to this is a product that I have not seen - a USB battery pack with a built in inductive charge pad.
[edit]annnnd like most of my ‘brilliant’ ideas someone else has already had it, done it, and posted a video on how to do it. Still going to work on it.[/edit]
I apologize… The thread is long, my memory poor…
I impulsively purchased 8 30Q batteries on eBay… Didn’t pay attention, and they are flat top……I was a bit mad at myself, but this morning I popped them in…and the light worked ,ramped right up to Max output…
But is there something I should worry about, am I forgetting something . The battery discussion was so long ago….
Thanks
Tony
There is a possibility that the wrap may get torn while screwing the tube on. It is also not certain that all four batteries are making contact. which means that your run time will suffer and your cells would get mismatched. Do you solder? IIRC test results indicate that the best performance is from flat top cells that have been modified with a solder boob - a small mound of solder on the positive terminal. A quick search of BLF for either “solder boob” or “solder blob” should get plenty of how to’s.
[edit] I just found a nice vid thread Barkuti did using ‘Roses metal’, but the technique is the same regardless.[/edit]
If you can, you should put a drop of solder on the top of each of them. They’ll make better contact that way. As it is, you have no way of knowing whether ALL of the cells are contacting completely all the time. You might end up with unbalanced cells.
