I hope it’s not just one of those in the business end:
Q8 on steroids
How is Q16 going?
thr lowerd one is a development host as far as i understood ;)
Interesting…
They are the same light as far is I can see. It just Hasnt passed the mill.
We need a REAL xhp70.2 thrower this time.
:+1:
Pretty good and not nearly as bulky.
https://skylumen.com/collections/v54-lights/products/mateminco-mt35vn-heavyweight-70-2-thrower
You won’t get it here.
Buy GT and do a swap.
Really sad it not comes with active cooling :cry:
I hope this can handle more than 10k lumens continuous :heart_eyes:
The first light to come on the market with active cooling is probably going to be by one of the bigger, more high-end companies and it’s going to cost a small fortune. You can’t expect active cooling on a budget light.
I think the most continuous power light on the market can only do 6k lumens. You really can’t expect a big jump to 10k continuous. You have to follow the rules of science.
Looks like it has 120~130mm head diameter.
4x XHP-35 HI, 11k lumens + 800kcd
or
5x XHP-70.2, 28k lumens + 250kcd
I think it was more like 10 xhp70 or 70.2.
Looking at the side profile, it may use TIR lens instead of reflector. I hope not. I think shallow SMO reflectors would give a good mix of throw and flood.
Yep, exact same proportions, same shapes, same number of fins, etc.
I just saw a review for a flashlight called Storm RA.
Made by a company called, silent ordnance.
The thing is a beast of a thrower.
These are the specs:
Welcome to the Storm of Ra, at 600,000 candela it is one of the most powerful production throwers of all time, but with vastly more lumens. How many more? 8000 lumens at the emitter, about 6000 lumens out the front, and we don’t mean reflector style mostly wasted in wash, we mean 6000 lumens IN THE BEAM! But wait, unlike the typical soupcan blaster, there is no turbo, this light can operate continuously at this output thanks to active cooling.
The Storm of Ra is a light born from innovation and experimentation. We make extensive use of 3D printing, it is just an incredibly cost effective way to prototype and generate jigging and tooling. It is a tool which allows us to easily test exotic optics setups, novel forms of thermal management, unusual power configurations, but what if it could be used to make a complete light? This question arose one day when we were working on the design for a powerful all-wood light. We were prototyping with a 3D print, and it was noted the prototype itself was a remarkably effective and complete light in its own right. With a few tweaks for interface, production, and function it’d be fantastic. Would there be a market though for such a product? It’d have the advantages of light weight, modest price, and staggering performance. But would the undue stigma of 3D printing haunt it? We had no idea, but before pressing forward with what’d be a vastly more expensive hardwood gigathrower, we thought we’d release the Storm and see what people thought.
Modes are controlled by a three position toggle switch. Rearward is off. Flicking the switch to its center position turns the light on. The forward position is a momentary off, allowing the same intuitive and familiar mode switching common to tailswitch lights. Firmware is GuppyDRV rev.2.
If this concept gains traction, far from the last, this will be just the beginning for both lights and accessories. What about an adapter to run the storm off a vehicle? Or something even more monstrous? The sky is the limit, but if people like this concept the price doesn’t have to be too.
Color:
Quantity:
-Up to 600Kcd illuminates 1570 meters (.975 miles) ANSI throw.
-Up to 8000 emitter lumens, 6000 OTF lumens*
-Comes with a signed card certifying your specific light’s performance and authenticity.
–220mmx200mmx160mm (length x height x diameter)
-GuppyDRV rev. 2.0 w/ 6V LVP
-No turbo mode, light can operate continuously on high
-Performance measured at 6 meters after 30 seconds.
-XHP 70.2 4000k (*denotes 5000K variant)
–6V low voltage protection
–2s battery config, two 20700s (recommended) or two 18650s (circumferential spacers suggested). HIGH DISCHARGE CELLS, >20A, REQUIRED!
-Heat tolerant and impact resistant ABS body
*OTF lumens are ALL incorporated into the beam, unlike a reflector light where approximately 50% are wasted in wash.
How come no one here has thought of a beast like this one before? If this company has managed to harness the power of the XHP 70.2 free emitter to make a thrower with 6000 lumens at the hot spot, why did no one attempt making a thrower like this here before?
App apparently they made another thrower that has 2,000,000 cd. That’s 2 millions cancels folks. It seems to me like they had already created their own giga thrower.
Any thoughts?
2 million candela it’s what I meant. Forgot to mention it also had a big heatsink and a fan on the back as well.
well - that 3Dprinted lights are not really of my taste ;)
Yeah it’s basically a 3D printed light that’s not weather proof, has an exposed fan, an ugly beam and 15 minutes of runtime on high (uses two 20700 or 18650).
Any thoughts?
My thought is that it has nothing to do with this thread.
Let’s talk about the MF03, shall we?
