Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
FUD? What is FUD (if it safe to say)?
Fear. Unbelief. Doubt.
O K. Thanks.
Thanks for the answers. :slight_smile:
Actually, I believe that’s, Fear, Uncertainty, and Doubt.
The Q8 isn’t intended to be a thrower, so don’t worry about it.
OOPS! You’re right. I didn’t look it up. I was trying to go from memory. :person_facepalming:
Actually I’d like it to be more throwy….somewhat akin’ to DT35. It won’t work this way, but a set of dedomed SST-40s will bring it closer. :slight_smile:
Spreading FUD about the meaning of FUD. :+1:
It seems much faster and easier to just carry a spare set of cells. Less bulk to carry, and you can’t use the light while charging the cells in the field. Are there any advantages at all?
There’s the coolness factor, that means more to some than others. Spare cells in a plastic box is so mundane. :wink: s
The idea is from the MF02 thread, will the Neodymium Magnets be ok to use for contact in the Q8 using non-button batteries instead of soldering the blob?
No, you can’t use magnets on this type of light.
The magnets would get wiped sideways as the head and tube are screwed together
Hello,
I have a new Cheat Sheet for NarsilM v1.2 ready.
NarsilM CS v12 Q8 2017-11-23.pdf
Download
Discussion
I gave my Dad a Q8 for his 89th birthday, you should have seen him “beaming” when he fired it up in Turbo outside. :smiley:
He and Mom both want to punch,punch,punch the switch button, they may end up with it in configuration mode or things changed, but hopefully he’ll get the hang of it. He’ll be taking it tomorrow to their weekly game day and showing it off. :wink:
Edit: Probably worthy to note, Dad grew up poor in the mountains of Virginia. He remembers the only light they had at night was a carbide lantern. (other than a candle or torch, of course) The little carbide pellets reacted with water and gave a gas that would power the light, and they wore this on their head! Yikes! :wink:
Acetylene. Was used in the mine headlamps
Link
I took my Q8 for a walk. Incredible light.
Thanks to all involved. And thanks to all BLF. :slight_smile:
