Hello, where can i purchase this powerbank
Woooooooo! There is English language inside!
To enable open menu by long press right button on the screen with version
Scroll down with right button to 16th point
Long press right button
Choose 25th menu point
Choose “En” by right button
PROFIT!
That’s cool! Before you had to get hold of the English firmware and flash it.
Yeah. That’s why I bought stm programmer, but looks it’s useless now.
Sorry guys. My store was closed for about a week as I was very busy packing stuff up at home to prepare for my move overseas. The store is now open again. Unfortunately I will not be carrying any YZXstudio products anymore. I made a post on the EEVBlog forum a while ago explaining the reason: Starting a new chapter - Page 1
—Franky
The concept is exciting, but the batteries are put in parallel, or without ORing MOSFET control, the weaker battery will kill the others. The iPad batteries are connected via ORing MOSFET control, which is the “secret” for battery longevity.
How can I buy this power bank?
https://item.taobao.com/item.htm?spm=a230r.1.14.117.d0fa2880UCL3OM&id=564706369813&ns=1&abbucket=5#detail
https://item.taobao.com/item.htm?spm=a230r.1.14.172.d0fa2880UCL3OM&id=520229554757&ns=1&abbucket=5#detail
Thanks!
Is it normal that I can’t find any XYZStudio products in BuyInCoins?
Is it also normal that I can’t login in even if I registered?
Finally, how I actually use a Taobao agent? Sorry, first time done it.
Bump. Sorry.
I don’t know BuyInCoins, so can’t say if anything is normal.
Why not just buy from taobao?
Because for some reason, my credit card company blocks Taobao transaction every time, and the hassle of having to go and physically approve the transaction is too much in my opinion.
I have some questions regarding this very interesting power bank (thanks for the nice intro & review!):
- Is version 8 still the newest variant? The review is from 2016
- If not, what are the differences btween it and the newer verison(s)?
- What is the standby current when the display is turned off and the device is lying around unplugged?
- If I reduce the charge voltage of the batteries and increase the minimum voltage to prolong their lifespan (for example min = 3.5V, max = 3.9V), does the percentage display react accordingly?
- What happens to the percentage display of the remaining capacity when a fast-charging device is plugged in and the voltage of the batteries drops?
To me the most interesting details about this power bank are that one can set the min & max battery voltages to increase the lifespan and that high-drain batteries can be used. They work much better in cold temperatures wallowing the power bank to truly be always ready.
- Yes, it is still the latest variant from YZXStudio.
- Standby current should be lower than in generation 7, because the springs have been replaced with soldered cells.
- I would expect the powerbank internal BMS to react accordingly.
- I like to try this when my copy has been married to some cells. Currently i have to find an service provider who offers point laser welding on batteries.
I have some questions for this forum too:
Which cell is best suited to use in the YZXStudio Powerbank?
- Sony Konion US18650VTC6…3120mAh, 6A charging, 30A discharge (my favourite)
- Samsung INR18650-30Q……3000mAh, 3A charging, 15A discharge (second choice)
- LG INR18650HG2……………3000mAh, 4A charging, 20A discharge (not as good as the Samsung)
And does the powerbank use a sensor to control the temperature of the cells?
Thanks for your answer!
It doesn’t matter which of those cells you use. I would buy the cheapest of those three. They are very similar.
There seems to be a 9th generation:
https://item.taobao.com/item.htm?spm=2013.1.20141003.9.639f5802VLcdYI&scm=1007.10011.70203.100200300000001&id=15147936768&pvid=57d6d592-0078-4f3b-bc4c-3859ced4e1d8
You’re right, great!
110€ without cells and 160€ with 3x 3450mAh 18650 cells.
But the 8th generation has 4x 18650 capability and there’s an version with even 8x 18650.
But does it still have the display with the U.I. etc.? That’s one of the main features for me. It’s also extremely expensive!
