ENEDED
The difference https://budgetlightforum.com/t/-/44818
  1. Better optics
  2. Small output gain
  3. Runs cooler
Code please for NW silver. It’s available now.
Code Please! Thanks!
is there any word if there is a fix for this issue yet or when the lights will ship?
Thanks
INTErested
Have to wait till Black Friday Sale is over. It is hard to get hold of people during major sale period.
Replied.
Thanks Freeme
Im interested - White NW please.
I’m interested in a black one with NW, depending on price. Thanks.
Interested in one NW Thanks!
im in NW
Freeme can you send me the code please! and thanks!!
I just took batteries out of the MT03II 70.2 and found out the 2batteries were at 4.2V still full but other 2 were at 3.90V. Haikelite should look into the problem right away and I think most of the first badge are defected.
How is it even possible that 2 cells are not making contact?
The polarity protection rings? Are you using button top cells as recommended?
Is there a problem in the tail cap pcb? A burnt trace maybe?
The 2 emitters were blinking like disco light since the first time I turned it on and I have already E-mail Haikelite about the problem. They promised me that they would give me a good solution but I have been waiting for about a month now and still no solution LOL. Now new problem.
What type of batteries are you using? Do they fit around the plastic polarity protection rings?
I’m using Sony VTC6.
Button top?
If you using flat top it may not work and that is what is causing the non contact.
They reccomended LG HG2 which are the same as Sony VTC6.
“You will need raised cells but not button tops. The button tops will not fit the light properly. It will still power on but it will not be waterproofed because the battery compartment will be open. I suggest LG HG2 or any style of battery that will work in series.”
Do button tops add so much length?
So raised flat tops?
Maybe regular flat tops, but with thin magnets added?
I guess you could solder blob them to get just a tiny bit more height so they make contact.
