I got my first UT01 today and I experienced exactly the same thing as you described.
At first I put in black eneloop NiMH cell. No matter what I did, it didn’t turn on. Then I tryed 14500 pkcell and voila, it works! Then I swapped this cell again with previously non working NiMH cell and now … it works!
Strange.
As noted elsewhere, my first UT01 only works well with AA NiMH, with an unprotected 14500 it needs to be power cycled after being turned on once. I just got a second, in the hope it would work with a 14500. It arrived a couple of days ago, and so far, so good!
Still, I’m gun-shy about ordering another, even though I’d like a CW.
Just throwing this out here as a wild guess……do you suppose these things have some sort of capacitor on the driver that has to ‘pre-charge’ a bit when a battery is first installed after a period of being empty?
One of mine wouldn’t work right out of the box, but after sitting with a battery in it for a half hour or so, began to work and has worked properly ever since. Another works 100% reliably with a lithium primary, but doesn’t with a NimH unless it sits for a while - then it also comes to life until the voltage gets down to about 1.2 volts, where it just plain quits with no warning whatever. (I don’t have any 14500s).
Another thing I’ve noticed; I have other 1xAA lights with EOSLAMP drivers in them, as well as a couple of stock 4Sevens Minis. When a Lithium primary is playing out, I’ll see ‘high’ and ‘medium’ at the same level for a while, then eventually ‘low’ on all three settings, then a few minutes of fluttering and ‘wavering’ until it finally gives up the ghost on a totally empty cell. The UT01 just quits. When it’s done, it’s done, and it’s lights out with no period of sag.
Weird little lights, but when they work right, they’re a real gem! I figure if I can get three out of four that work, I’m still getting a bargain. The emitter alone is worth most of the ten bucks.
I have a recent Haikelite SC01 that has an on issue.It will just flash after clicking 3 times, taking off tailap and replacing let’s me turn it on after clicking 3 times. Currently looking for fixes related to this light. Another two Haikelite HT35 lights have switch or electronic issues. They will come on only if there is an exact amount of pressure from the tail cap to the battery. Gently pulling back on the cap as I tighten allows the light to come in. I’ve got another Haikelite MT01 that works okay but it is somewhere in the house that I cannot find it. Lol!! Ridiculous issues with Haikelite!
After work fine for a few days, I put the fully charged 14500 in, the light got hot with a smell of something burned inside then I changed another 14500 the light turn on by itself and can’t change mode or turn off. With Ni-Mh it can’t turn on anymore.
Open ticket to GB they offer 5$ refund or spend more 2$ for a new one :person_facepalming:
Well, mine is improving, at least, so it seems.
It’s down to just a few clicks before it turns on.
So i think i’m not gonna bother opening a ticket.
None the less, it is a problem they seem to get away with (either GB or Utorch).
I have the same issue, i’ve been using a 14500 for a few weeks without issues and suddenly after switching off it can’t be switched on again. But i can turn the light on when i loosen the tailcap breaking the battery connection then the light switches on and all the modes works. With NiMh same problem. With an alkaline AA even weirder. It can’t go to high or turbo or any of the strobe modes it just shuts off completly. But with an AA alkaline i don’t have to loosen the tailcap. Very weird problem. :weary:
I submitted a ticket and got the stock please read the warranty policy and send us a video reply. Odd given they must be aware of the issues with the light
Try measuring the battery lengths…mine seem to work better with the shortest batteries.
I suspect the double tail springs might be using too much interior space and perhaps keeping the tail cap from contacting the tube properly in some of the lights.
I notice my UT01 CW’s button (where the + battery makes contact) is not flat but slightly depressed/inclined, so making contact with a flat-top is intermittent, button-tops (NiMh) seem to work properly.
However, I’ve occasionally (not often yet) had the flashlight not wanting to turn off after it’s turned on — I had to unscrew the cap to turn it off. Not sure what’s the problem. This is with both the UT01 CW and NW lights (I have both).
I tried different kinds of batteries 14500, alkaline and nimh. I ordered a few of these lights currently just 1 has the problem. But then again the other ones i haven’t been using daily. Once the problem occurs it stays. All of the batteries are making good contact. Once it’s on the clicks are 100% accurate. I’m no expert but I suspect it has something to do with the voltage regulator or the low voltage protection gone haywire.
