Are there any C8 triple setups still available?
I dont know why I need to say it each month, but once again:
Yes, first post is updated as soon as some item is sold and most time actual quantities are listed.
Upd.
When I dont leave exact quantity but write āin stockā this usually means more than 10pcs stocked.
I apologize for the repeat inquiries of your products I just seen the price but no quantity I probably should have asked what the quantity was available for the C8 not if they were available, my bad.
No problem.
When somebody will meet this thread first time and see such questions he could think that there is no actual stocks.
Ok no problem.
I will say that the new quad M2 setups look amazing in the light with the new glow o-ring itās definitely adds a great look and appeal to the light! I would add some photos if I knew how to lol.
I have made several test fits and found out than Š¤20.1mm circle can perfect fit inside stock positive contact ring.
Any ideas about proper height? 2.0mm to make it 0.5mm taller than stock contact ring?
+1 for the UF-1406 and/or 1405 pills if thatās still on the table. Canāt seem to find anything better than the light-weight aluminum crap it comes with reverse threaded in. Thanks!
Sorry, moq for threaded parts is 50pcs.
What is moq?
Minimum Order Quantity
Thanks, that makes sense. Has the demand been anywhere near 50 or much less? I feel like these are popular lights, especially to mod. And the only pills available are really crappy aluminum
Near zero.
Does that mean I have to order 50 pieces to get it? Or you have to have 50 people interested in it before you make them?
Very interesting looking , reminds me of the Lux-RC FL33 :
Quad or triple ? and what tube will it fit ?
Let first make it real
If that is what I think it is, it will provide amazing sustained brightness/size paired with a well regulated driver, canāt wait to know more!
Yesterday I received an order from kiriba-ru (1 Copper pill triple Convoy S2+ ā custom retaining ring, both pill and ring have milled cuts; 1 Copper spacer for Carclo triple Convoy S2+). Took 21 days to arrive at my house (Portugal), tracked package.
Iāll use these for 1 or 2 triple builds Iām planning.
Just wanted to show some pics in order to compare it with a regular S2+ Pill, as it may be useful for those intending to make a mod
Quality is excellent and this really got me pumped to get the rest of the components, as I think this pill will be a beast in functions :sunglasses:
Some points Iād like to mention:
- The retaining rings are different, but each one fits perfectly the other pill, no threading problems;
- The pill fits perfectly on the 4 Convoy S2+ I have, threading perfectly as well;
- The spacer is solid and well built, and will imply a mod in the āregularā pill (drilling its center for the wires), but they match perfectly.
I want to thank to kiriba-ru for the nice work done in here! Keep it up
