Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
Thanks for the detailed explanation, JasonWW.
I think my flashlight IQ just leveled up! :wink:
I am using those:
Compared to 30Qs, the output is like 250 to 300 (lux @ ceiling bounce) , so I suppose it’s good 4,5k lumens.
Shall I ask BG for replacement LEDs/driver? Or someone here wants to look at it?
After a night rest, leds were good. But after 1hour green light began to blink again.
Are you referring to the batteries d_t_a linked to?
They do not appear to be the same. Different button top size, different button top ring, different sticker on side. I’m pretty sure the protection circuits where added by two different companies. Most likely different circuitry added.
I killed a cell doing this runtime last night, so everyone can enjoy my fuck-up. This is with GAs and thermal management disabled because I normally use it outside where it’s too cold to matter. Let’s just say it got rather hot.
Are you saying heat killed the battery Bob? I have done lots of testing with run time tests with thermal management switched of with 30Q’s in the Q8, yes the light does get extremely hot but I’m yet to kill a battery or damage any other components in the light.
I know, just posted an example of NCR18650B’s that works in my Q8 without problems. A little less light than 30Qs, but longer runtime.
I wonder what happened in the second Q8…. while problems with switch LEDs were happening already (though I got Q8 from the second batch, after September production stop), the delay in mode switch is pretty strange.
I’m not sure what happened, but one of the cells was dead after the test (reading 0.8V right now and dropping). They are new flat top GAs, but I haven’t had any issues with uneven drain. The light did get rather hot.
I had some liitokalas failing sone moths ago , out of the blue . They just turned 0.1V after one or two days after they were charged . One of them was inside a light (not a parasitic drain issue) , the other not . Still a mystery what happened…
The flat top 30Q’s that I had worked in my 2 Q8’s even before I soldered some 14 gauge wire (bent into a small circle) to the top of them. The only reason I added the wires was that I was concerned that the wrapping would be ripped off the top of the batteries when the body was screwed down. Solder blobs work just as well but I like the look of the wires so that’s what I always add to the flat top’s to raise them.
I made a diffuser out of a sauce bottle. After you cut the top off is is a push fit. Big W and Spotlight carry these in Australia. I also put a small convex blind spot
mirror in the bottom to block light from going straight out the end, and reflect it downwards and outwards.
Mr Excitement. lol cool
NICE! :crown: :+1:
Got any paranormal activities there? Ghosts like to suck the life out of batteries
http://www.ghostvillage.com/ghostcommunity/index.php?showtopic=23816
Form here: https://jonimayhan.com/2013/12/17/ghosts-and-electricity/:
"We call it “battery drain.” Prior to an investigation, we always check our batteries to make sure they’re fully charged. Sometimes though, we’ll discover that our new batteries become instantly drained the minute we walk into a haunted establishment.
Many enthusiasts feel this is a ghost’s way of powering up. They will drain the batteries, and sometimes even the energy of the investigators themselves, in order to communicate or manifest. After living in a haunted house for 13 years, I can tell you that there is some validity to this theory."
Hhmm. Might have triggered a safety cutoff. Think I heard/read even unprotected cells have some built-in safety circuitry. You might be able to "wake it up" by applying some juice to it - cheaper chargers can do it as well. Same way we can wake up a dead protected cell when the low voltage of the PC trips.
Hahahhahahahahahhahahahaha insane Tom , really funny :smiley: :smiley: :smiley:
Braided Lanyard with Tripod Connector:
http://www.enogear.com/pd.jsp?id=147#\_pp=0_455_26
Sorry for repeating myself, but what should I do with faulty Q8? ( Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light - #16508 by FreeMagenta )? Should I go to Banggood or ask Q8 Team? :slight_smile:
Hmm… The Miller had been handling support issues, which gives us significantly better results than a random tier-one support agent who doesn’t know much about the product… but he has been too busy lately so I’m not sure. Is anyone else in the project able to help?
Darn it. I somehow missed the release of the Q8's. I was in for two?
1228 ARsee
1229 ARsee
