Does anyone have an idea of candela? looks impressive in the pictures.
京东(JD.COM)-正品低价、品质保障、配送及时、轻松购物!
京东JD.COM-专业的综合网上购物商城,为您提供正品低价的购物选择、优质便捷的服务体验。商品来自全球数十万品牌商家,囊括家电、手机、电脑、服装、居家、母婴、美妆、个护、食品、生鲜等丰富品类,满足各种购物需求。
About 0.72 times of D1s lux value for my 3m test. Not going to supply the measured values as I suspect my readings are on the high side for my GM1020 meter.
Interested
BG's listing says 800 meters, which, doing the math, is 160 kcd. For a 54 mm head diam and true FET driver, I suppose this could be possible.
I got the M8, D1, and D1S all on the way, but may be a little while yet.
From the pic above, though the M8's head is wider, looks like the reflector I.D.'s might be about the same - the M8's bezel setup looks wasteful on reflector width.
As freeme measured, maybe the M8 is not a true FET, or is using thin LED wires and poorer performing springs, or could be just the difference between a XPL vs. a XPL HI. Hank's Emisar lights use the great performing Beryllium copper springs, here: http://intl-outdoor.com/gold-plated-beryllium-copper-spring-5-pcs-p-831.html, shown with djozz's spring test results.
M8 is XPL, D1S is XPL HI.
should the preorder promo end date have been Dec. 12? Looks cool. I like the ramping since I got the Q8
Thanks
preorder? i see only alert me on arrival.
BG has been suspended M8 preorder temporarily due to lack of stock. I will update once it is ready.
subbed.
Nice looking light.
Received mine today - came on one of those green plastic padded cases, cheap but ok. Spare lens, USB cable, lanyard., o-rings.
it's a 4000K XPL HI LED - did not expect that...
I know it's a 4000K because today I also received a D1S from Neal with a XPL HI V2 5D 4000K and they match tint pretty much exactly.
The UI may be a V1 Emisar - last used level is not remembered, so from OFF, a single click always starts at lowest. The 3X click is battery voltage, not SOS as noted earlier.
The ramping is klunky - not consistent, and intensity of the hot spot is not as bright as the D1S, but it could be the battery I used.
The 26650 battery tube is too narrow - one LK 5000 cell I tried will not fit, but fits a Manker U21 perfectly. I popped in a EVVA protected I had laying around, fits but it's tight, but the length is another problem - partially crushed the + cap on the EVVA.
On the M8 there is a switch LED, blue, but it goes on when the light is ON, OFF when the light is OFF.
The M8 is a slightly smaller carry light than a U21, but quite a bit bigger than a D1S. Reflector ID appears to be bout the same as the D1S because the M8 has a wastefully wide bezel, though it's a nice chunk of SS.
Where did you get it from Tom ?
Thanks
Edit : I guess banggood had it in stock some time ago , i thought they hadn’t any stock at all
BG - ordered Nov 11th, shipped Nov 24th. Dunno - maybe they shipped a couple of them before stopping. I had a knee arthroscopic surgery done Monday so haven't been downstairs yet where my stuff is - I'm still using crutches, so can't do much in testing/inspection yet.
The battery tube seems like the biggest issue - upsetting to not be able to use LK 5000's because I got a ton of them and still think they are the best. Lack of a manual is weird too. Just noticed the driver has a retaining ring - dunno what to call it, but has the 2 holes for a tool and it's not threaded, just clips in there - seems quite unusual in a flashlight.
Dunno if this is Hank's or not - need to see the driver - might help. The spring on the driver looks like what Hank uses in the Emisar lights.
It’s in stock now at BG and code works. (black color only)
Anyone know what size is the driver?
Also does anyone know where to buy the green color one or how to purchase it from here:
EDIT: is that site showing price in Yuan? 780y = $124 USD ??
How many are interested in green model?
Thanks freeme for considering the green model. Hopefully others besides myself will have interest enough to get some of them in stock for this deal.
This Maeerxu M8 has become my leading choice between it, the UT02 and D1S. No green color for the D1S like D1/D4, not sure I’d like the sandy texture anyway. I’m getting bored with all all the black or grey flashlights, would like something different, this green looks real nice.
The green color may not as bright as it looks in the stock photo I posted above, here’s some from the Chinese site that were posted in reviews, but camera’s, settings and monitors could show things differently.
Photos are extremely small as I couldn’t figure out how to view them full size on that site.
Green color show:
Interested in green
Interested in Green as well
I could be interested in the green, looks nice.
What emitter actually XPL or XPL HI ? Tom E got the XPL HI but at BG spec It’s XPL.
edit:
From the picture it looks like XPL HI.
edit:
Because of Tom, the photo and the distance spec (800m) I’m counting on HI, but Banggood really should fix that in their description.
