whoa!
I am spoilt by the sideswitch. I can’t abide twisties anymore.
The only tailies in my goto’s are the cuTools and only ’cause of their fantastic patinas.
Don’t think I’ll be in for one after all, sorry.
If I understand correctly, the button location is probably the single biggest difference between the FW3A and the Emisar D4. Also one of the most sensitive to personal taste. Side switch or rear switch may be enough to determine which one a person chooses.
I think the FW3A has several nice advantages though… things which aren’t really a matter of taste:
Three-channel driver with regulated modes up to about 3 Amps (instead of 350 mA).
Less tint shift and higher efficiency between ~150 lm and ~1500 lm.
Clip nicely integrated into the design and included by default.
Rounder beam (no pinwheel pattern).
More flexible / powerful interface.
Button somewhat easier to find in the dark, and easier to press when hot.
Lower price, probably.
Meanwhile, the D4 has some advantages too:
4 emitters instead of 3, so higher maximum brightness.
Bigger heat sink for higher sustainable output level.
More tint/emitter choices available.
More host colors available.
Works with 18650, 18500, or 18350. (possibly also 14500 and 16340 with a spacer)
Choice of two optics.
Is already possible to acquire.
Between the two, I suspect I’ll probably like the FW3A a bit more, but it’s a close call. For me, I think the FW3A’s clip and 3-channel driver and tail switch may outweigh the D4’s higher brightness and bigger variety. Won’t know until I try one though.
You can only hold a tailswitch in dagger or cigar/ette mode
I quit smoking in 1995 and don’t want memories of that experience
and Psycho scared the shite out of me
I tend to agree.
However this picture is very distorted - close up with a wide angle lens. I can’t even figure where head and tail are… The light looks ‘fatter’ then what we have previously seen too.
I hope we get to see some picts of the samples Lumintop sent a few days ago.
That clip is for me unusable, I have to replace it.
I need a clip parallel to to the tube and it had to be straight not pointy.
It is completely rubbish to add a magnet on.
