I built a triple with these awhile back and just did it like any other triple. I think I used 22awg. I have no issues with it over driving the LED’s since the Vf on them is pretty high.
Yeah, I forgot what the messured amps were but they were not anything to worry about, around 10 amps IIRC. I generally use GA’s in my personal lights but I generally test with 30Q. Either way it should not be an issue with a triple. Even if they are overdriven some it will not hurt then and it will quickly drop as the battery drains.
First of all thanks for your help. You not mentioned but i supose that the 10 amps (aprox) is with bypasess springs right? I think i will go with 22awg and phosphor bronze springs for driver and for the tail. And lets see whats the measurements are. Probably stay in 8-9 amps and thats will be perfect because from 9 to 12 ( in this led) its not much gain in lumens but more heat.
I learned early on that you can’t even see the difference between minor changes and even some major changes with the human eye. So why stress out over it.
For example going from 2.5A to full 6A turbo on an XP-L is hardly noticeable in the real world unless you see it side by side.
I would just build it with whatever fits and works in the host the best and then enjoy the results.
You won’t kill the LED’s regardless in a triple setup with a good thermal path which is the most important thing.
There’s a positive and negative side to the high CRI Oslon Squares in that shop: the negative is that they show a second generation led in the picture but the leds actually on sale are in fact first generation (with clearly lower old-school performance), the positive is that the first gen. Squares have way better tints than the second and third generation (green :confounded: ).
Not much of a problem for me with output, djozz. I was probably going to use them for some low current flashlight mod or small home lighting project, DIY stuff just for the sake of beautiful light.
I was already noticing v1.3 and v1.0 led versions the other day while inspecting the LCW CQAR.CC and GW CSSRM1.BM datasheets a few days ago.
Their COB emitters look really good for home/business lighting.
I have just one sw45, thanks to a generous member… it is in my pocket as EDC since it arrived… makes my hand look nice and pink, though the beamshot shows an unusual amount of violet in a photo, and Im not sure what to make of it, I really like using the LED, it is very “white” in the evening, not too yellow during the day.
(tint is relative to white balance) in this iPhone photo the auto white balance seems to have decided the 4500k N219b Worm is the white balance reference:
thanks for the link
I think the 219b are going the way of the DoDo Bird
I find the 219c less desirable in terms of being more yellow/green than the 219b, but, the 219c is brighter, and Imo Nichia is playing catchup with Cree(n)…. maybe Green Lumens are brighter than Red Lumens?;-)…
This photo of yours, jon_slider, clearly shows how a 219B 4K Ra9080 is redder than a 219B “worm” (4K Ra9050?) and how a 219B 4.5K Ra9080 is both redder and bluer. With auto white balance your device adjusts the RGB level information of the picture to more or less “match” that of the reference, this makes it useless or hard material to work with when comparing against photographs with a standard colour balance like “daylight”. The pictures we see in our information technology equipment are just too limited in their colour space compared to the amazing capabilities of the human eye, brain and mind.
It is for this reason that I nearly always shot with daylight white balance, with some sort of note when not. Example:
The usual daylight white balance temperature is probably somewhere between 5500K and 6500K across most if not all devices. This is the reason the above picture looks quite warm, though the actual pleasantness of the above light is much higher than what it may seem (CRI85+ emitter, too).
