[GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)]
I checked that first, they are listed as out of stock, so no preorder option? https://www.virence.com/blank-rwrlr/nvsl219bt-v1
Cool! (i mean warm)
Would like all the nichia please :smiley:
All your Nichia are belong to me…
Pre-order can only works if the custom is predictable. Learnt from many shipments in the past, won’t promise until they’re on my hands. And mount Agung eruption makes it even uncertain. It’s currently calming down but the seismic activity isn’t. Constant rumbling deep inside the earth and frequent earthquakes (hundreds per day) indicate there will be bigger eruption to come.
- Clemence
It’s so warm, almost amber. You can use it as a turn lights
Interesting:
LED dedicated Lee filters, with minus green, amber and diffusers.
UPDATE 171222, 15:28 GMT +8:
  • 1st Shipment delivered
  • E21A sm653 R9080 shipment postponed by Nichia due to technical reasons until early January.
  • Newer Nichia reels don't have voltage rank printed.
- Clemence
Store Re-stocked
Thanks Clemence! And I noticed that the 219B sw45k has no voltage rank too.
All of them
Got me some 2000K 90CRI 21A’s for some winter modding . Great effort Clemence! :+1:
Unfortunately the sm653 9080 E21A isn’t there yet.
I bet you’re going to make another cuddling mode flashlight. The output of sm203 9050 E21A only topped at D180. And Nichia couldn’t guarantee the availability of D180. These reel is a mix of D160 and D180 according the the PO. Hopefully you don’t get too much variations. I hope the variation would be gradual between LEDS next to each other.
- Clemence
Hi clemence,
Would it be possible for you to re-upload the pics in the OP? Almost every picture in the OP is no longer available. Thanks.
Same for other threads with your pictures.
Already fix some. Will do the rest (hopefully) after finished with packing tonight
- Clemence
E21A CCT & tint shots:
With faceted TIR lens, the 4 LED’s was very well mixed
The quadtrix under spherical lens. It’s just a bad aspheric lens from a cheap zoomie pull, please don’t complain about the beam.
- Clemence
what is “ALL” ?
sm203 + sm303 + sm403 + sm503 all at once
Check this thread: New VirEnce MCPCB for E17/E21/119/144/233U
Aha, i see. :slight_smile:
