Test/review of DMM Aneng AN8009
16 posts / 0 new
HKJ
HKJ's picture
Last seen: 55 min 46 sec ago
DMM Aneng AN8009
DSC_3924
This is the latest incarnation (Late 2017) of the this small fairly cheap meter.
DSC_3905
It did not include a box, but was delivered in an envelope that contained the holster.
DSC_3906
Everything was inside the holster.
DSC_3908
It included the DMM, two pair of probes, a thermosensor and a manual.
DSC_3919
DSC_3920
The standard probes has removable tip covers.
DSC_3910
The other set of probes fells rather low quality, but has some nice functions. They consist of two wires with threads at both ends and a couple of different tips that can be mounted in each end. It is slow to use, but very flexible.
DSC_3911
DSC_3912
DSC_3913
DSC_3914
DSC_3915
DSC_3916
Here are all the different tips.
DSC_3917
DSC_3918
The thermosensor is a real probe, not just the small bead at the end of wires. The plastic has a crack.
I am not convinced that this is better than the bead, that is smaller and easy to stick on just about to any surface with some sticky tape (Buying one as supplement is cheap).
DSC_3929DSC_3936
The body of the DMM feels solid, the plastic is rather smooth, i.e. the DMM can easily slide on a surface. The tilting bale is rather flimsy and do not give enough support for pressing buttons and turning the range switch.
DSC_3925
DSC_3926
DSC_3927DSC_3928
DSC_3930
Display
DSC_3931
The above picture shows all the segments on the display.
Not all the segments are used on this meter.
DSC_3932
Typical display during usage, it will show the number and what measurement is selected.
DSC_3933
Non contact voltage will show from one to four bars depending on the electric field strength.
Functions
DSC_3934
Buttons:
  • Range (Blue): Will disable auto range and change range, hold down to activate background light.
  • Sel/Hold (Yellow): Select the ranges printed with yellow, hold down to freeze the display reading.
Rotary switch:
  • Off: Meter is turned off
  • V % Hz: Show voltage, using the yellow button will cycle between VDC, VAC, freq. and duty cycle.
  • mV: Show millivolt, using the yellow button will cycle between VDC, VAC, Celsius and Fahrenheit
  • 100Mohm: Resistance, continuity, diode and capacitance, work up to 99.99Mohm
  • Hz: Frequency and duty cycle, this is used for lower voltages and works at fairly high frequencies.
  • A mA: Current AC and DC (The meter is missing some mA ranges).
  • uA: Low current AC and DC.
  • NCV: Non contact voltage.
Input
DSC_3935
  • A mA: A very low burden voltage mA range and a 10A that cannot really handle 10A.
  • CON: The common terminal for all ranges.
  • xxx: All other ranges, including uA. It is always problematic when a current range shares connector with a voltage range, if the switch is in the wrong position the (hard to replace) fuse will blow (at least). This will only affect current, voltage will still work.
Standard probes will work, but can not be fully inserted.
Measurements
  • Volt and frequency
    • 1 VAC is 5% down at 2.1kHz (RMS will not work at the frequency).
    • At 1Vrms input frequency range is from 1Hz to 6.6MHz
    • Input impedance is 10Mohm to 11Mohm on DC and AC
    • mV range is high input impedance for DC
    • Frequency input needs about 250mV to work at 1kHz.
    • Frequency counter and duty cycle works without zero crossing in Hz range.
    • Duty cycle works from 2% to above 99% at 100kHz with 2Vpp (1Vpp do not work), precision is within 0.8 (About 0.8 too low).
  • Current
    • 9.9A range is badly calibrated at high current.
    • 9.9A range will change some percent at 5-10A current due to heating.
    • 9.9A range will give an audible alarm when current is above 9.9A (uA will not).
    • Current ranges are limited to 36VDC and 25VAC.
  • Ohm, continuity, diode and capacity
    • Ohm needs about 2.6s to measure 100ohm
    • Ohm voltage is 1V open and 0.38mA shorted
    • Continuity is very fast (About 4ms).
    • Continuity beeps when resistance is below 50ohm.
    • Continuity is 1V open and 0.38mA shorted
    • Diode voltage is 3.2V with display of up to 3.000V with 0.14mA, maximum current is 1.6mA shorted
    • 70000uF takes about 9 seconds to measure.
  • Miscellaneous
    • A beeper will sound shortly before the meter turns itself off
    • Current consumption of meter is 1.6mA to 2mA (8.7mA with backlight)
    • Meter works down to 2.2V where it turns off, battery symbol show at 2.4V.
    • Readings are stable with changing battery voltage.
    • Backlight only works down to about 2.6V where it is fairly dim.
    • Viewing angle is good.
    • Display updates around 3 times/sec
    • Backlight will automatic turn off in about 120 seconds.
    • Will automatic turn power off in about 15 minutes.
    • The meter usual need a couple of display update to reach the final value.
    • Weight is 136g without accessories, but with batteries.
    • Size is 130.4 × 65 × 32.3mm
  • Probes
    • Probe resistance 55mOhm for one.
    • Probe wire is fairly soft and 65cm long.
    • The probes with replaceable tips has 55mOhm with 4mm plug.
    • The probes with replaceable tips has 87cm long fairly soft wires.
1uF
A look at the capacity measurement waveform.
DMMschema
Tear down
DSC_3991
Four screws and the back could be removed.
DSC_3992
DSC_3993
The circuit board is shaped to fit the enclosure.
DSC_3994
3 more screws and two clips, then I could remove the circuit board from the front.
DSC_3995
And two more screws and two more clips to remove the display.
As usual the connection to the display is with a zebrastipe and there are two wires for the backlight.
DSC_3996
There is not much on this side, only the switches and the connector pads for the display.
DSC_3997
Everything is on this side. Near the 10A fuse (F1) is the uA shunt (R23 & R24: 99ohm+1ohm), this shunt is protected by a diode (D5) and a 200mA fuse (F2).
The voltage input is handled by two resistors (R29 & R20: 5Mohm+5Mohm) and there is a small PTC (PTC1) for protecting the ohms/capacity current output. The two transistors (Q3 & Q4) is protection after the PTC.
The part marked Q5 is a ICL8069 1.2V reference and Q1 is used to turn the background light on and Q2 the buzzer.
There is a EEPROM (IC1: 24C02A) to handle calibration and define function in the multimeter, the big blob is the main multimeter IC.
There is a trace at the top of the circuit board between the two LCD mounting holes, that is the NCV antenna.
DSC_3998
DSC_3999 DSC_4001
DSC_4000
DSC_4002
Conclusion
The meter is easily within the specified tolerances (Except 10A) and it has lot of functions and ranges, but the CAT rating is fake.
This is a small DMM in size, but has most of the expected functions in a universal DMM. It has a hole in the current range, it can measure currents in that range, but with fairly low precision, instead it has very low burden voltage in the mA range and low precision at high current. Temperature and NCV is a good addition to this version of the meter.
I do not like the small fuse size, they cannot break high voltage or high current and they can be hard to source locally (They can be found on Ebay). The current range on the voltage input is also a bad idea.
The 9999 count secures the best possible resolution for 4 digits.
I will call it good DMM for hobby use, but keep it away from anything with mains voltage and lots of amps.
Notes
This meter may exist with many different names on it and small variations in functions.
How do I review a DMM
More DMM reviews
XXX-Man
XXX-Man's picture
Last seen: 9 hours 50 min ago
I got this dmm 2 days ago and was hoping to see review from you.
Thank you for your work.
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F
maukka
maukka's picture
Last seen: 2 min 58 sec ago
Thanks for the test!
Although the price is great for the overall quality I dislike the shallow probe connectors on the small Anengs. I’d also like a bit higher bandwidth (at least 20kHz for audio applications).
HKJ
HKJ's picture
When I received it, I put it first in the review queue.
To get higher AC bandwidth you need a considerable more expensive meter. You would probably also like dB readout.
XXX-Man
XXX-Man's picture
Thank you for that Smile
I am now sure it will be perfect dmm for my needs.
I needed something to keep in my tool box for quick fixes.
My reviews:
Milan
Last seen: 6 days 4 hours ago
I think the ZT102 incarnation is currently unbeatable.
Only 6000 count, blue/green back, 1 pair of probes
But for USD 9? Ughh
+Cardboard box + Pouch
There is already number of reviews on youtube:
https://www.youtube.com/results?search_query=ZT102
btw any cheap source of the fuses?
HKJ
HKJ's picture
Milan wrote:
I think the ZT102 incarnation is currently unbeatable. Only 6000 count, blue/green back, 1 pair of probes But for USD 9? Ughh +Cardboard box + Pouch There is already number of reviews on youtube: https://www.youtube.com/results?search_query=ZT102
All the AN800x or ZT10x meters are basically the same meter, there is small variations in the range switch and the configuration in the EEPROM. I do not know if the firmware in the DMM chip is the same.
This means it is important to select meter depending on what ranges you want.
I do also have a review of the AN8002 in queue, but I will probably publish a few other meters first.
Try ebay, but it must be a fast fuse for best protection.
DoubleA
DoubleA's picture
Good review Thumbs Up
I would like to ask you something, I have an AN8008 and when using eneloop cells it’s backlight is very dim but using 1.5V Zinc Carbon cells the backlight glows at full brightness. Can you confirm whether this problem exists on your AN8009 model?
and on the first day he said "Let there be light"...
HKJ
HKJ's picture
Backlight is the same on these meters and as I write in this review it is very dim at 2.6V
Milan
DoubleA wrote:
Good review Thumbs Up . I would like to ask you something, I have an AN8008 and when using eneloop cells it’s backlight is very dim but using 1.5V Zinc Carbon cells the backlight glows at full brightness. Can you confirm whether this problem exists on your AN8009 model?
I wouldn’t call it problem, it’s how LEDs work.
You can use fresh alkaline or zinc, or rechargeable LIFEPO4 for full brightness.
DoubleA
DoubleA's picture
Well Aneng should have known that’s how LED’s work. Silly
I have a cheapo IR Temperature gun and it’s back-light works fine with NiMH cells because it probably includes a boost converter.
HKJ
HKJ's picture
When making a very cheap meter, there is not money for a boost converter. Another solution would be higher battery voltage, i.e. 3 batteries or a 9V battery, but then the meter would have been larger.
DoubleA
DoubleA's picture
Another solution would have been to use a red backlight. Evil
Barkuti
Barkuti's picture
Last seen: 3 hours 13 min ago
https://www.aliexpress.com/item/1pcs-lot-MT3608-2A-Max-DC-DC-Step-Up-Power-Module-Booster-Power-Module/32650402967.html
Backlight problem DIY solution, though using LiFePO4 cells is much easier and no modification is required.
Cheers
DoubleA
DoubleA's picture
There are even smaller modules than that.
Like this Tiny Buck converter
and then this Tiny charge pump
True, Soshine 10440 IFR cells come with 2 free battery spacer dummy cells.
Then there those Kentli cells with regulation and also there exists AAA with a built in micro-usb charger.
joechina
Last seen: 1 hour 23 min ago
For a deeper discussion of any kind of DMM with mods and changing stuff in the firmware lock at the eevBlog Forum.
e.g.
https://www.eevblog.com/forum/testgear/latest-aneng-9999-dmm-invented!-a...
