Cheap S2+ mods
Yes.
Uhm… the picture shows it, or is that a blackened S2+ which wasn’t black before?
Yeah, you can mess around with rings and what not, and then put a load of super glue in the tailcap (on the inside).
I have done a few tail caps with that SS button.
My C8 has one (inside a magnetic ring from Convoy), my Astrolux SS has one, my SS UltraFire S3 has one, and more will follow.
Those buttons are cheap at Fasttech, like $1.75 a pair.
That’s an understatement.
It’s like they’re made of butter…
Thanks for the suggestion. I have further questions….
I see that other sellers offer 1288 switches (without Omten name) for half the price. It’s not worth to risk getting junk, is it?
I also see that Simon sells beefier switches, “10A” for 50% more. I recognise that for S2+ with regulated driver they won’t make any difference. But since they are sold in batches of 10 I’d rather buy something that works great in a wide range of lights. Are those significantly better?
Also, I see KAN-9 10A switches for less that Simon’s 1288….Considering that KAN-28 did well in Djozz tests, this one should be even better and likely as good as Simon’s 10A, am I right?
These are my favourite switches:
https://www.aliexpress.com/item/Flashlight-reverse-switch/1572591646.html
10A switches wont fit S2+. Smallest light I could fit them is p60 solarforce.
These will:
They’re a big switch in a small package.
They are reverse clicky, and I didnt found anything about 10A rate.
[quote=Jerommel]
Show us your wares. :face_with_monocle:
Okay :disguised_face:
Those are:
Astrolux SS - SME SME-626
….fire S3 - Convoy C8 (with magnet ring)
The SS and the C8 are without centring gasket because they’re for a lighted switch.
In both cases light can also pass through around the buttons.
Maybe i’ll show you later.
how did you solve the hole diameter problem?
Mainly with O-rings and super glue.
For the SS (top left) i found an acrylic ring that’s almost invisible.
But it’s difficult to explain without pictures…
Ok, but how is it possible to remove them if you use super glue?
Also in this thread they’re mentioning metal clicky S2+’s have a bit more tail length to accommodate the metal switch. Do you have any problems fitting metal clicky into shorter tails?
I don’t know why i would want to remove them, but with force and / or some heat i think you could remove them.
I can work around that.
The SME and the S3 have no PCB between the switch and the spring.
In the S3 i even put an Omten 1288 switch inside the retainer ring.
Again, super glue to put the spring on the bottom of the switch. Bypass wire to connect the spring to the switch.
I also raise the buttons as far as possible so that the lights can still tail stand (that’s the first step).
The C8 and the SS have enough space inside.
Acetone. Dissolves cyanoacrylate no problem.
probably also dissolves the anodization? :weary:
AcMe? Why should it? Need something like lye to do that.
After swapping in a DrJones H17F driver I am mostly happy with my desert sand S2+. The only improvement I’d wish for is bi-directional mode switching. Unfortunately the driver is over $10.
OK, my Convoy switches arrived today.
First look: I need to cut the legs to make them fit. But then the size is perfect.
Then I opened one to get it lubed. Result: it came lubed already. The internals are way beefier too.
Then I soldered it, success, not melted this time. :slight_smile:
The circular part is too large to fit the cap holder ring, I increased the ring opening somewhat….and the switch works. :slight_smile:
The spring is much stiffer than the stock one, so it needs more force than stock despite lubing. Makes much lower sound when clicking, I like it.
Where did you find the metal switch for the Astrolux S41s? I want a metal switch for mine REAL BAD!!
Awww! so where are they available?
