I got 4 big CPU fan and 4 x 100W crappy array that i would use.
I cut with my cnc machine the plate to install all the stuff
I started with a simple 250V 15A switch but it burned the first time i turned it on… I have 32A sucking the lipo (4000 6S)
So i put a simple OMRON SSR relay
Ok it output a lot of light with a small efficiency (coz of the crappy 100W arrays) but that’s funny to use it.
8min run time with the lipo
Size comparison with nitecore concept1 and astrolux MF01
that’ t actually pretty simple build.
Each 100W array is feeded with a BOOST DC module (3$ ebay) because i use a 6S lipo battery (24V) and each array need 33V.
I also use a drone PDB board to solder everything and have a 12V mini psu for the OMRON SSR (12 Vdc coil) and for the 4 heatsink fans running at 12Vdc
I’ll compare that to the MT03 and MF01 tonigh. That’s floody light.
