Any change for good deal of Astrolux S41?
Yes, of course - see next post
Astrolux S41 4x Nichia 219B/XP-G3 A6 1600Lumens Mini LED Flashlight
It’s right now in promotion for only $22.95.
Offer ends on December 21.
Additional 18650 body tube to achieve light full potential with high current 18650 cells is available here(now in black, blue and red):
Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.80 |
$2.76 |
$2.73 |
$2.70 |
$2.63 |
Yunmai Y3 T6 5Mode 1000LM OP Reflector 18650 EDC LED Flashlight
It’s now in flash sale for $4.69.
Offer expires in 4 days and 14 hours.
Keep in mind that the LED is probably not genuine Cree but some Latticebright or other clone. You get what you pay for.
But if you need some potentially disposable 18650 flashlight - this might be good enough. See reviews @banggood product page - there are some pictures.
Yunmai Y5 XM-L2 800LM Mini Portable EDC LED Flashlight 18650
It’s in flash sale for $9.99
This one supposedly has quite good built quality and even neutral LED option.
Good mode spacing: ~ 4Lm > 40Lm > 360Lm > 800Lm
Klarus Mi1C Ti/Cu XP-L HI V3 600Lumens Compact Mini EDC LED Flashlight
Coupon code for nice price drop (~33% less) is available
» Request details via PM here«
In case you missed it those are Copper and Titanium versions.
Nitecore SC4 LCD Display USB Rapid Intelligent Charger For Li-ion/IMR/LiFePO4/Ni-MH Battery
Use coupon code dba0fb to lower the price by -$15.00
Wuben LT35 XP-L2 V5 1200LM 5Modes USB Rechargeable Tactical LED Flashlight +18650
Use coupon code YLT35 to lower the price to $21.74
18650 battery is included
Astrolux S42 4xNichia 219C/XP-G2/XP-G3 A6 2023LM Rechargeable Mini LED Flashlight
It’s now in fash sale for only $24.95
Offer expires on December 21st.
For use with high current 18650 cells to achieve full light potential additional 18650 body tube is available here: Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.80 |
$2.76 |
$2.73 |
$2.70 |
$2.63 |
I have a S42, I would advise read the reviews! There’s a thread best lamps 2017, I doubt the S42 makes it there.
HaikeLite MT07S HI Upgrade Version 3000Lumens CW/NW Long Range LED Flashlight 1200M
Non-public coupon code is available for hefty 35% discount
- Cree XHP35 HI
- 4 versions: black/”white” finish with Cool White/Neutral White LEDs
- max 3000lm (2.5h)
- min 50lm (28 days)
- SMO Aluminum Reflector
- Ultra Clear Double-sided AR coated toughened Glass lens
- 1200 meters (~1300yds) range
- powered by 4x18650 cells
- 8mm thick integrated shelf for efficient heat dissipation
- Power indication light (LED indicator under switch button)
- tripod mount socket
- lockout function
Update: flashlight is in promotion until 19 December for even better price!
Convoy S9 XM-L2 580Lumens 4Modes USB Rechargeable EDC LED Flashlight 18650
Newest release from Convoy - finally standard micro USB rechargeable :+1:
It’s in preorder for $19.95 - $20.95 (depending on LED tint).
Promotion price is now $15.95 ~ $16.95
Three tints available: Cool White (6500K), Neutral White (4200K), Sun Light (5000K)
KLARUS XT11S Xp-l Hi V3 1100LM Classic Tactical Setting Outdooors LED Flashlight 18650
Use coupon code 0c6239 to lower the price from $79.95 to $51.99 (-$27.96).
- Klarus 18650 2600mAh battery Included (along with holster, spare oring, lanyard and USB cable)
- standard micro USB rechargeable
- max 1100lm (2h), low 10lm (260lm)
- 3 programmable modes
- triple switch design (side switch with LED and dual back switches)
- direct access to turbo, low and strobe modes
- LED voltage indicator (LED in side switch)
- constant current driver
- dual springs for gun recoil/shock resistance
Update: corrected wrong pasted coupon code.
Klarus XT11GT XHP35 HD E4 2000LM Tactical Outdooors LED Flashlight+18650
Use coupon code b2a4cc to lower the price from $87.95 to $57.95 (-$30.00)
- Cree XPH35 HD E4 LED
- Klarus 18650 3100mAh battery included (along with holster, spare oring, lanyard and USB cable)
- max 2000lm (50min)
- min 10lm (170h)
- 3 programmable operation modes
Sofirn SP31 XP-L2 V6 1021lumens 4+2Modes EDC LED Flashlight 18650/CR123A
Use coupon code YSP31 to lower price by -$8.98 to $10.97 ($19.95)
This is probably the cheapest double switch 18650 flashlight on the market with that deal!
See detailed pictures on the product page - looks like quality build and incredible value.
Sofirn SP31
Just ordered.
Thanks
You’re welcome
SP31 looks like an amazing deal! These days u can really get a good flashlight at a cheap price.
I have 3 more SP31s on order and received my first yesterday. I like the size and weight very much. Its barely larger in diameter than an 18650 battery. Output is pretty decent for a light of this size. It’s not near as bright as the Zanflare F1 , atrolux s1 or the convoy S3 but I estimate around 900 lumens which is good for the size. It is smaller and lighter than all three of those lights.
The dual switches are nice.
I wish the tint was a little cooler but I like cooler light than most here. I estimate it’s around 5000k.
Bottom line, for around $10, its a very good buy. Compared to $12 (coupon) for a Zanflare though, I will take the Zanflare.
Astrolux K1 XP-G3+365nm UV+Red LED 350LM New Driver USB Stainless Steel Mini LED Keychain
Version with XP-G3 is now in preorder for $18.95 ($32.95) until Dec 19th.
