Yes, gotta take price/quality into consideration no doubt! But no reason to quibble over cutters here. I’ve got plenty of small pliers that can cut piano wires and nails!!!
This thread will be mostly usefull for US members. EU import limits (for companies) restrict product assortiment and raise prices on local markets. Im almost sure that you can find knipex dealer in your country, but wont find many Taiwan brands.
However, I think this is not far away from you: http://proskit-bg.eu/en/pliers/cutters/heavy-duty-cutting-plier-wconductive-handle-1pk5101e.html
LED reflow also works great on a small temp regulated hotplate
Or just a plate of aluminum that provides enough thermal mass so the heat up and cool down follows close to the temperature profilen that is recommended from datasheet,
you can heat it with gas torch or hot air gun
IR thermometer is also good for reflow temperature check
Can’t help ya though.
But I think sticker shock will follow.
I just use solder tabs. Use a high watt iron and be QUICK. Allow to cool if you need a second try. Put Kapton tape under the tabs, on the edge of batt (Pos side) for safety.
No prob, thanks for the reply!
Yea, i’ve looked at prices. Sticker shock did follow lol. It will def. only be bought if I pursue building battery packs heavily (quite possible but not presently).
Thanks for the tips! I was figuring something like that would work fine if you paid close attention.
Thermal adhesives:
Fujik (bad but often good enough, cheap), Arctic Alumina (good, expensive)
Thermal Paste:
Arctic MX-4 is recommended often
Overclockers’ pastes are mentioned often too
Recently I bought GD900 and I think it’s a good choice for cheap lights.
Liquid metal is the top pick for copper lights, but destroys alu ones
I use Arctic alumina for thermal adhesive for thing I need a better bond.
MX4 (Computer thermal paste) for thermal paste under emitter MCPCB to aluminum pills. If I use a brass pill I usually solder the MCPCB to the brass.
Also got some generic silicone thermal Plaster. Used that in the TIP around the reflector before assembly.
Never bought diamond files, have a couple sets of the 12pk generic jewelers files for fine work and various other smaller Nicholson files that can be had at the Orange store. Wet/dry variety of grits 220-2000 and red scotchbrite are must have on my bench.
I bought this S Mini Black Copper with intentions to expose the high spots of copper. What I did not expect was the nickel plating between the black and copper. I had to hand file the entire surface to expose copper and sand it out after. Turned out good but took 4X longer than I anticipated.
You can see the transition of the layers at the side of the SW in this pic.
