I mentioned the 4000K two weeks ago in the other UT01 thread. I like it too, but it is way off the 3D tint that the site and the package claims.
Last night I was comparing some lights.
I have some 5A tints in other 1xAA lights (emitters that I got from Intl-Outdoors), and these ‘alleged’ 3D UT01’s are remarkably close - which is fine by me. :+1:
I have Astrolux S1 3D (neutral white), the tint of which I like.
Comparing the UT01 neutral white (supposedly “3D” tint), this is a much warmer — in fact I compared it with a Convoy S2+ (XM-L2 T6-4C tint), and the two tints are closer to each other, or the UT01 “3D” could even be very slightly warmer…
Decided to do some more pics while I’m at it…
Lighting under fluorescent tube
Astrolux S41S Nichia 219B (90CRI — based on product description when I bought this)
(This is the closest to what the floor looks like in actual)
Astrolux S1 XP-L (3D tint)
Convoy S2+ XM-L2 T6-4C
UTorch UT01 neutral white ‘3D’
using a budget digital camera with setting “Daylight” white balance
Not a fan of this NW tint on UT01. I’m hoping I like the CW version better.
Any idea about the current draw or lumen output for those three options on the firefly mode?
How did you know yours were off-center?
Here are some Lumen output numbers with NiMH…
Not sure what it is with a 14500.
Thanks, I only use eneloops so I don’t want to know 14500. I’ve been reading a lot about UT01 in this forum and it seems there are problems when using NiMh so I guess I won’t be buying this and go for Sorfirn SP10B instead.
That would probably be wise.
I am not sure what the current draw is. FWIW I leave my UT01 on candle mode overnight all the time… many nights in succession. I use it as a nightlight with a 2000mah eneloop.
I got my CW UT01 finally. For walking outside, I think I do like the CW tint better.
CW and NW optional?
Welcome to BLF LTVictor.
The light is available in Neutral white or Cool white.
I have the NW and it is warmer tint than the described 5000K. I would say closer to 4000K.
Closer to 4000k? Nice. I ordered both tints. Maybe the CW will be decent.
Latest lights are reported with 4000K Emitter
I just got a “NW 5000K” that I ordered around 11/11. Yes, the tint is definitely more like 4000K.
It’s an okay tint, but I think it has a tiny bit of green in it. I don’t hate it but I would have preferred a genuine neutral white.
I am tempted to order a 6500K if there is another deal for 10 bucks. Normally I don’t like cool white but this light is a bargain.
Interesting. My NW UT01 is really rosy and not green at all.
I guess they changed emitters recently, here’s a (shortened) quote from the Lumintop EDC05 thread
I hope the UT01 I have arriving from GB doesn’t have ugly green tint, I could deal with the Convoy 4C comparative but not the green. Also hope I get a good switch.
I’ll be looking for feedback to see how this Lumintop version pans out, I really like the tail magnet.
I ordered the UT01 as an alternative to an 18650 light that’s about the same size with about the same output “(DQG Tiny 4th)”:https://www.gearbest.com/led-flashlights/pp_271697.html
DQG Tiny 4th: 86mm x 22mm (850lm)
U-torch UT01: 84mm x 19mm (800lm)
I was afraid of the smallish size, non recessed button on the DQG, I’ll be sacrificing a lot of battery capacity but the UT01 appears to have a larger button, plus it has a reflector and the nice programmable UI. Although I’m really impressed by the size of the DQG, being it’s about the same size as a 14500 light.
I have the DQG 18650 Tiny 1st version (Twisty) and like it, and unlike many others have reported, I’ve had absolutely no problems with mine whatsoever.
Maybe I mistake the green tint for the warmer light (I don’t have any light warmer then 5000K) so I opened the box and checked it again.
Externally the only difference is that the new UT01 have smaller text on the tailcap.
The new UT01 to the RIGHT.
Did some beamshots with my crappy Chinese phone camera just to see the difference.
The new UT01 to the LEFT.
Hard to see with bad pictures but you clearly see a difference.
I can’t do single beamshots of each flashlight to shine at a white cealing since the camera autofocus would ruin them.
Decide for yourself but that new UT01 went back in the box.
waiting for mine to arrive from Gearbest, $9.99 What are the chances of getting one with a good switch? From all I read I’m a bit paranoid. But I love programmable lights.
I think your chances are pretty good. Out of four, I got three that seem to be perfect, and one that was a bit ‘off’ to begin with - but a piece of wire in the tailcap, and constant use seems to have worked out the kinks.
There are some things that might be worth paying attention to before you ever put a battery in .
Check the five little prongs on the back of the driver to see if they stick up very high. If they do, trim them before you install a battery. If a flat top 14500 were installed, all they’d have to do is stick up higher than the “+” bump on the driver to possibly cause a short.
Check to see if there’s any gap between the tailcap and the tube. Some of mine have measurable gaps, while the problematic one had no gap at all, and I think the ano on the cap was meeting the ano on the tube shoulder before the circuit was made. A circle of copper wire inside the tailcap fixes that., and even adds enough length to accommodate slightly longer batteries.
I’ve only had experience with the one troublesome light (which is no longer troublesome), but I have learned a bit and tried to put to use some of the clues posted about the UT01. The foregoing only might help. I can’t comment much on possible 14500 issues; I don’t use them.
You mentioned the switch (as have several others). Mine had a ‘crunchy’ feel to it when it arrived, almost like 3 or 4 steps in the brief length of its travel. I think it was internal debris of some sort; it actually smoothened itself out to where now it’s indistinguishable from the rest of them. Others have reported worse problems, so YMMV.
I’ve been using this ‘problem’ light hard. It has rarely left my hand since it arrived a few weeks ago, and it’s gone through about three NimH cells and a couple of Lithium primaries as a night light, a table light, and to light up rooms instead of flicking on a wall switch. I’ve been trying to make it fail, and instead it just got better.
I’ve been lucky; I hope you will be too. I think your chances are pretty good.
