I’ve already managed to mess up my prototype a little. I replaced the 1x7135 chip with a different brand to see if it’d help, and it seems to have made the driver stick out a little so now I can’t thread the thing together quite as far. It still works, but I’ll have to fix it next time I take out the driver.
OTOH, I greatly improved the button debouncing. It’s not 100% yet, but it’s at least like 90% now.
Regardless of how the tapered section works out, whether it’s 5 degrees or 45 degrees or 90 degrees, the narrow middle area makes the light much more comfortable to hold. It fits comfortably between any two fingers, which isn’t something I can say for most of my 18650 lights.
This prototype has the wrong emitters (XP-G2), and there are some thin wires, and my main contact points are weak at the moment due to the replaced chip not fitting quite right, and my battery wasn’t full, but I did some quick output tests…
Moon: 0.24 lm (after swapping 1x7135 chip)
1x7135: 160 lm
8x7135: 1063 lm (highest regulated level)
FET: 2160 lm
The real thing should go significantly higher (though keep in mind the high modes are basically burst only, not for sustained use).
I also like the orignal the design better (even more with a 45 degree slope). But like ToyKeeper mentioned before, this way it gets a bit more thermal mass and that is (to my opinion) something this light could use very well. But I rather would have seen it in a different way (a thicker wall maybe). I still like the inside of this light so I would buy it anyway.
Several times now I have headed out to the lathe to build a light, with the internal components in hand and no design cues in mind at all. Start out making the tail switch fit into a bar stock and then machine a copper light engine to hold the driver and emitter/s of choice. Then put the pieces together and shape the outside to whatever feels right. It’s odd maybe, but doing it that way the design takes it’s own shape on-the-fly and has produced some really neat and interesting results. Like making the battery tube fit my fingers in the grip I like to use, then seeing it resembled to spools of thread stacked on top of each other. I like machining it after it’s assembled because it makes the two pieces seem as one, even a transition between copper and aluminum the metal seems to be one piece that abruptly changes colors. I like that, it amazes me. (I’m easily amazed, true enough)
So it’s not that I don’t like the ramp on the tube, it’s just that I was drawn to Fritz’s primary design to begin with. It was more Raw, elemental, form following function. And so it goes, it’s never-ending….
I don’t know how long a quick burst is yet, and don’t know how the thermal regulation will behave yet, because I haven’t measured it yet or adjusted the code to fit.
I can probably trim the chip’s wide tab down to fit.
… a few moments later …
Yeah, okay, it wasn’t the 7135 tab. The driver has a notch on one side, and so does the host. It just wasn’t rotated the right way.
While I had it apart, I also fixed debouncing. It seems to work 100% so far.
Really wished the prototype could have come with the XPG3 emitters that were planned so we could see what the tint/beam would look like.
Maybe the next round or someone could swap some in?
I don’t have any argument on latest design, it’s great, but it’s just different from the initial one.
Wishing that I can get the light as initial design which is already in my mind.
Haven’t checked this thread in a while. I think I prefer the tapered shape because I expect it to slide in and out of a pocket more easily. I do really appreciate the looks of the original, but I’m very much in the form follows function camp and it looks like the new form will function better. I liked the polished look better, but I use lights when it’s dark, so that’s not a priority.
I’m really glad to see that ToyKeeper is working on the firmware. Just using Narsil seemed like a good enough plan to me, but TK working out all the kinks should make it free of annoying glitches and well-tuned for the hardware. Thanks, TK!
I still think it needs more Niciha. As more XP-G3 beamshots in various optics show up, I think that more than ever. The XP-G3 always seems to make a beam that looks like a bruise. Yes, I can do that myself, but not everyone can, and it adds 40% to the cost.
As for what the final beam will look like, has anybody built a Convoy triple with these and a 10507? That should produce an essentially identical beam.
