I have a S42, I would advise read the reviews! There’s a thread best lamps 2017, I doubt the S42 makes it there.
HaikeLite MT07S HI Upgrade Version 3000Lumens CW/NW Long Range LED Flashlight 1200M
Non-public coupon code is available for hefty 35% discount
» Request details via PM here«
- Cree XHP35 HI
- 4 versions: black/”white” finish with Cool White/Neutral White LEDs
- max 3000lm (2.5h)
- min 50lm (28 days)
- SMO Aluminum Reflector
- Ultra Clear Double-sided AR coated toughened Glass lens
- 1200 meters (~1300yds) range
- powered by 4x18650 cells
- 8mm thick integrated shelf for efficient heat dissipation
- Power indication light (LED indicator under switch button)
- tripod mount socket
- lockout function
Update: flashlight is in promotion until 19 December for even better price!
Convoy S9 XM-L2 580Lumens 4Modes USB Rechargeable EDC LED Flashlight 18650
Newest release from Convoy - finally standard micro USB rechargeable :+1:
It’s in preorder for $19.95 - $20.95 (depending on LED tint).
Promotion price is now $15.95 ~ $16.95
Three tints available: Cool White (6500K), Neutral White (4200K), Sun Light (5000K)
KLARUS XT11S Xp-l Hi V3 1100LM Classic Tactical Setting Outdooors LED Flashlight 18650
Use coupon code 0c6239 to lower the price from $79.95 to $51.99 (-$27.96).
- Klarus 18650 2600mAh battery Included (along with holster, spare oring, lanyard and USB cable)
- standard micro USB rechargeable
- max 1100lm (2h), low 10lm (260lm)
- 3 programmable modes
- triple switch design (side switch with LED and dual back switches)
- direct access to turbo, low and strobe modes
- LED voltage indicator (LED in side switch)
- constant current driver
- dual springs for gun recoil/shock resistance
Update: corrected wrong pasted coupon code.
Klarus XT11GT XHP35 HD E4 2000LM Tactical Outdooors LED Flashlight+18650
Use coupon code b2a4cc to lower the price from $87.95 to $57.95 (-$30.00)
- Cree XPH35 HD E4 LED
- Klarus 18650 3100mAh battery included (along with holster, spare oring, lanyard and USB cable)
- max 2000lm (50min)
- min 10lm (170h)
- 3 programmable operation modes
Sofirn SP31 XP-L2 V6 1021lumens 4+2Modes EDC LED Flashlight 18650/CR123A
Use coupon code YSP31 to lower price by -$8.98 to $10.97 ($19.95)
This is probably the cheapest double switch 18650 flashlight on the market with that deal!
See detailed pictures on the product page - looks like quality build and incredible value.
Sofirn SP31
Just ordered.
Thanks
You’re welcome
SP31 looks like an amazing deal! These days u can really get a good flashlight at a cheap price.
I have 3 more SP31s on order and received my first yesterday. I like the size and weight very much. Its barely larger in diameter than an 18650 battery. Output is pretty decent for a light of this size. It’s not near as bright as the Zanflare F1 , atrolux s1 or the convoy S3 but I estimate around 900 lumens which is good for the size. It is smaller and lighter than all three of those lights.
The dual switches are nice.
I wish the tint was a little cooler but I like cooler light than most here. I estimate it’s around 5000k.
Bottom line, for around $10, its a very good buy. Compared to $12 (coupon) for a Zanflare though, I will take the Zanflare.
Astrolux K1 XP-G3+365nm UV+Red LED 350LM New Driver USB Stainless Steel Mini LED Keychain
Version with XP-G3 is now in preorder for $18.95 ($32.95) until Dec 19th.
Coupon code 1abad6 for selected Nitecore, Klarus, Imalent JetBeam and Lumintop flashlights:
LED Flashlights Christmas Celebration 30% OFF
collection.
BlitzWolf® BW-T1 XP-G3 S4 750Lumens Portable Tactical LED Flashlight 18650
Newest release from Blitzwolf. Simple no-nonense 18650 EDC flashlight. It’s now in preorder for $10.99 ($19.99)
Offer expires on December 25th.
- Cree XP-G3 S4 2A tint (~5000K)
- 4 modes: high 750lm (3.5h), medium 250lm (5.7h), low 70lm (19.9h), strobe
- 147m (160yd) range
HaikeLite MT03 II Devourer XHP70.2 2SPS New Driver 12000LM High Power LED Flashlight
Use coupon code 90656f to lower the price from $119 to $95.
- 3x Cree XHP70.2
- max 12000 lm
- N4 Cool white or N2 Neutral white tint options
- black or silver/white finish options
- 10 lm lowest setting
- LED power indicator (lighted switch)
- copper DTP emitter board
- Ultra Clear double side AR coated glass lens
Jetbeam TH15 XHP E2 1450Lumens Ultra-High Performance Tactical Outdoor LED Flashlight
Use coupon code JTTH15S to lower the price from $99.99 to $66.99 (-$33.00)
- Cree XHP35 E2
- Jetbeam 2600mAh micro USB rechargeable 18650 battery included (along with holster, clip, tactical ring, 2 spare orings, lanyard and spare rubber cap)
- max 1300lm ANSI FL1 (3 min turbo step down + 1.1h high 900lm)
- dual switch (side click + tailcap switch)
- power indicator LED in side switch
- two operation modes (outdoor + tactical) with multiple output levels
- min 10 lm (140h using 3500mAh battery)
- 228 meters (748 ft.) range
- one touch strobe hidden in outdoor mode
- momentary on
- patented Jetbeam “triple tail” switch for easy operation with gloves
- stainless clip for EDC
- 18650 or 2x CR123 power source
- constant current LED driver
- compatible with remote switch(sold separately)
HaikeLite SC02 II MTG2 2000Lumens Stainless Steel Head LED Flashlight 26650
Use coupon code HSCO2II to lower the price from $65.99 to $43.60 (-$22.39)
Eagle Eye X7R XP-L V6 1000Lumens 5Modes USB Rechargeable LED Flashlight 18650/26650
Use coupon code X7RSD to lower the price to $21.60 (–28%).
Cool White (1A 6500-7000K) and Neutral White (3A 5000-5500K) versions available.
1PCS GETEED 3.7v 4800mAh 35A High Power 21700 20700 Rechargeable Li-ion Battery
This is probably first widely available 21700 li-ion cell. Use coupon code ET217SD to lower the price to $9.68 (–12%)
Judging from 9.5A discharge plot (below) this cell is well suited to high power mods:
ADEASKA SQ2 Intelligent LCD Display USB Rapid Battery Charger for IMR/Li-ion Ni-MH/Ni-Cd Battery
Use coupon code ADSQ2S to lower the price to $11.69 (–30%)
- 0.5A/1A charge current for li-ion cells
- 0.5A charge current for Ni-Mh/Ni-Cd cells
- standard microUSB power input (DC5V/2A)
- USB output (power bank function)
- realtime voltage monitoring
- battery capacity, time and current display
- refresh function for over-discharged cells
- over discharge protection for USB power bank function (3V +/- 0.2V)
- temperature monitoring
- reverse polarity protection
- 2 years warranty
ADEASKA SQ4 Intelligent LCD Display USB Battery Charger for IMR/Li-ion Ni-MH/Ni-Cd/LiFePO4 Battery
Use coupon code ADASQ4 to lower the price form $39.99 to $26.79 (-$13.20/-33%)
- 0.5A/1.0A/2.0A charge current for li-ion cells
- ability to charge 4 26650/32650/D size batteries at the same time
- 6A max output (all slots combined )
- USB output (power bank function) with 2.1A output
- power bank works with cells in any slots
- internal resistance measuring
- battery capacity, time and current display for each slot
- 2 years warranty
