This driver is for 12V LEDs, SBT-70 is a 3V one and wont work with the current it needs
XHP35, 50 and 70 will work well
for XHP50 and 70 a Star with the thermal pad not connecting the 2 LED pads over the thermal pad is mandatory
so for 12V reroute over a separate trace would be needed
Those Sinkpads are OK, MTN, Fasttech and LEDDNA sells em
This LED star will not work if the star is not insulated from the body
parts and boards for 30 drivers ordered
(10% extra parts for tests and maybe 3 boards from Oshpark)
I also added the 2x2 LED boards to the Seed order,
so if you like different colors or just more even lighted switch you can take one as well
I got SMD LEDs in different colors
CW, NW, green, emerald green, yellow, orange, red, blue, ice blue and pink
Hi Lexel. I guess you received my payment for two drivers, just cant see my name on your spread sheet. I slipped you a couple of dollars extra so all should be good here.
