Thanks 18sixfifty
Just modded my first ever Convoy! A S2+. Now with a DD fet driver. stunning light.
Nice job and great write up.
I agree, a de-domed SST-40 is a great replacement for the XPL-hi. However, in these small zoomies the XP-G2 de-domed still has itās place, not better or worse than the SST-40 just a different application. If someone is looking for the maximum throw in a extra small zoomie but still wants a decent amount of lumens with good run time the XP-G2 is another good way to go. Even the XP-E2 has itās place in these small zoomies. Stick one on a noctigon and use a 2.8amp driver with an attiny on it and you can still program it. You get great run times, less heat and lots of throw as well.
I just did a super cheapy SKYwolfeye TLY-6501 zoomie the other day for a friend and used the XP-G2 S4 2B de-domed for this exact reason. Since you like zoomies you might like them. Itās one of the smallest 18650 zoomies, the focal length on the lens is actually pretty darn good for being so small. There are cheap too, you can find them for under $4.
My first emitter reflow! From the ashes of my deceased D4, the first flashlight to receive an emitter transplant was my Lumintop Tool AAA, from cold white, which I didnāt fancy much, to a loving 90+CRI 5000k!
If the wires look soldered wrong, is because I reflowed the emitter wrong, hehe, still not bad for my first reflow still
Next I think will be my Nitecore TIP, maybe an S2+ and the last one is still looking for a host
Good job Persechini. All down hill from there. Especially after the tiny light you did as a first.
I had not touched a solder iron for two weeks until tonight so I had to do something quick to prevent withdrawal symptoms.
I got my Jetbeam E40R in today. I just adore the design, the modes are good, but the user interface is not well thought out (a bit of a disaster really with the loooooooong press for on and off). And at Jetbeam they probably thought they were pretty modern to put a SST-40 in it, but that emitter is too for me.
Nevertheless I like the E40R, for the design, and it has onboard charging which is very nice. So I found it worthwhile swapping the emitter for a XM-L2 3000K 90CRI, sunny and warm , but the output is down to 725 lumen now.
Note for others modders: the bezel is glued tight with blue stuff that only gave way after extensive heating with a small blowtorch and brute force.
I gave my little Thorfire TG06 a complete make over a few weeks ago but never got around to posting it. This one has the smooth reflector in it.
I put a Fet driver in it with dedomed XP-L emitter on Noctigon and spring bypasses at both ends. Then I decided it needed to look different than the other TG06 I have so I sanded off some of the Anodizing and polished out those areas to get thisā¦ā¦ā¦.
Then a few days ago I got a NEW Convoy L2 host , 20mm MTN FET 7135 + 1 driver , 20mm Noctigon and a XP-L HI V3 3C to put in the L2. I got that all done and of course did spring bypasses at both ends with 20awg Turnigy wire.
The L2 has a great beam and making 1491 lumens now and I was very happy with it , UNTIL I noticed that the Bezel and the tailcap both had the Anodizing just flaking off of them on the very ends , even though the light had hardly been messed with other than the mods and about 10 mins of testing and a couple of beamshots.
The very end of the tailcap was the worst even though it had only been sitting on a wooden shelf and had my thumb over the end clicking the switch.
The rest of the Anodizing seems to be fine , other than the Bezel and tailcap sections.
I decided instead of making a big deal of it or trying to get a replacement or what have you, I would just make the L2 Unique.
I used some aluminum cleaning acid I have and took the Anodizing off the Bezel , Tailcap and the flat ring where the āConvoyā logo is etched in down to the bare aluminum. I then polished those areas just enough to give the bare aluminum a Satin looking finish , instead of the highly polished look. Also I put the Black switch boot back in to match the light better in the end.
Overall I am pleased with the way this project came out.
Here is what the light looks like now and also a beamshot at 175 yardsā¦ā¦ā¦ā¦ā¦ā¦.
Another Nichia swap. This time 219b 4500k r9080 in Lumintop Prince.
Robo, that L2 came out SWEET! The clear areaās have such a nice velvety look to em, beautiful work there my friend, beautiful!
I putted in an Osram oslon square 4000K 96 CRI led to a friendās Utorch UT01.
And reflowed four same led on to a quad noctigon which is going in to my Thorfire VG10S with carlco 10622 and TA fet driver. Now Iām waiting for the spacer to be done.
Matchbox Instruments HF-R Ti.
Iāve been working on this the last few days and it has finally ended up an XHP50 light with GITD rotary switch markers and a momentary side switch.
There is a thread with a fairly thorough teardown for anyone interested in how these are built.
Built my first driver from parts. Tiny85 and D4 v2 Ramping_IOS was ordered programmed from MtnE. Did the assembly with an iron and a quick re-melt on the stove. 30mm driver, 20AWG and bronze spring
It Works!!
Excellent work on the HF! Mine was one of the first ones and oddly, it doesnāt look like that!
VW, very clean work on that driver, fun isnāt it?
Yeah its fun when its done and works. If it didnāt work I would be SOL with no clue why.
30mm is going into SD26, if all goes well it will also charge.
Have a 17 & 20mm to build next. 17mm is for the C8F.
Any clue if anything needs to be changed in the D4 UI code for 2S like the L6?
Very cool; to both vwpieces and CRX
Thanks
I am wanting to see some Hot Air action Don.
2 emitter transplants today:
Nitecore HC30 with cool white emitter got a spare XM-L2 3B tint I had from from my S2+ triple
Nitecore TIP 2017 also cool white got the 2nd 219C high CRI 5000k from the late D4
Notes:
- Broke the lens on the TIP, and have no idea how to replace itā¦ I hope my local glass shop will have the tools do cut a circle this tiny. Scratched the reflector a little too, but it doesnāt appear to be affecting the beam
- I never quite got the snapping effect people show and tell about reflowing emitters, I had to manually center the emitters and by consequence the MCPCBs spent more time on the pan than Iād like, the TIP MCPCB even started to peel of the positive pad and started smelling a little funny. Is this because there is less solder than needed? I never added any extra solder, I just used what was left over on the MCPCB and back of the emitter
- So far these are 3 (2 from this post and the Tool AAA previously) cool white flashlights that I made into my preferred 5000k tint, 2 of them are now also high CRI. The 3 of them have neutral/warm white versions that where either unavailable, not included in a flash sale, or unknown to me at the time of purchase, so now I have flashlights that I like a lot more than I did before and washed away any semblance of regret I had from buying the cool white versions. I donāt think I would have ever tried such feats if not for everything I see and read shared here, so thanks BLF for that
Me too! I have other stuff āin the wayā. I need to complete the big bookcase project first. Getting close to being done; stained the last pieces this morning.
Some pics of the earlier mentioned Osram Oslon square 4000K 96 CRI led replacements:
Smaller than XP but not really difficult to fit because the thermal pad has almost the same width.
Beautiful colors with 96 CRI
One in the Utorch UT01:
On the left: UT01 Osram, On the right: Nitecore TIP CRI
Left: UT01 XP-L CW, right: UT01 Osram
