[Review] Astrolux S42 4xNichia 219C Rechargeable Mini LED Flashlight supplied by Banggood
I was just curious. Did you do any work with HaikeLite to help improve their drivers? They are saying their MT09R and recent versions of the MT03 are using a new TA based FET driver, but their own UI. I didn’t know if you assisted them or if they just “borrowed” your driver design.
Kinda sorta. They did ask me if they could use the design in their lights and I offered to help them but they decided to do it on their own and use custom firmware. Why, I have no idea.
I then got a message the other day asking for some kind of help with the drivers, so I am not real sure what is going on with them at the moment. I am hoping that I can talk them into using Narsil at least.
Finally heard back from Banggood on the S42 so I could start work on the driver. They want to use the LY4057 charging circuit which looks like it will work.
Got the main driver almost laid out, then start work on the charging pcb. I am not sure what footprint the USB connector is, still got to track that down.
Tell them how much a success narsil was on the Q8. I’m sure it would increase sales. It’s like a factory custom light. What could I do to mod it? Nothing! Lol
Well, if people were to start contacting them asking for Narsil to be used with the drivers it sure would help the chances of it being used.
Tell them I am happy to help them get it working, they have seemed hesitant to use outside help for some reason.
Narsil would be amazing, hope they are reading this thread?
+1 for narsil.
Hey guys, let’s go to this thread and tell Haikelite directly that we would like to see them using NarsilM on their TA based drivers.
~~https://budgetlightforum.com/t/-/47515/53~~
Oops, posted in wrong thread.
Astolux lights are manufactured by Matemineco!
Certain ones, but not all.
the S42 is not manufactured by HaikeLight nor will they build a driver for it
Yes, that would work really well as a UI on this light. Like a mini-Q8.
I updated the OP with my NarsilM replacement driver which accepts the USB piggyback board
Can you guys give me a little help? When I switch to Group 2, I only get 4 modes (Low,Med2,High1,High2) and I can’t get to turbo. I want to be able to enable memory so I can start at Turbo mode instead of having to cycle through each mode in Group 1.
Mode group 2 only supports those 4 modes. You don’t have access to turbo in that group. You’ll have to use the default mode group 1 if you want turbo. But, then you don’t get mode memory.
This light has a really weird UI. I’m making my own driver for it.
Lexel, you use the charger circuit that comes with the S42 on your mod? I’m considering making my own with MCP73831, but maybe it’s not needed if the S42 charger circuit is good enough?
I did lift old MCU so charger LEDs dont work anymore. but the charger itself stays connected with the rod and charges
TA made a design with new charging board
Thanks. I think I’ll just go ahead with my own design… it’s part of the hobby after all :slight_smile:
As soon as I hear from TomE to get a me narsil with the new pinout I will release the S42 driver that should be going in all future S42’s from the factory. Never could get narsil to compile properly myself.
A simple FET+1 TA setup but with Narsil it is a heck of a lot better then what it comes with now. Plus should increase the output a lot.
Damn I just ordered a S42! Ahh
Me to :person_facepalming:
I guess I’ll have to mode it with TAs driver when it comes out.
