[Review] Astrolux S42 4xNichia 219C Rechargeable Mini LED Flashlight supplied by Banggood
+1 for narsil.
Hey guys, let’s go to this thread and tell Haikelite directly that we would like to see them using NarsilM on their TA based drivers.
~~https://budgetlightforum.com/t/-/47515/53~~
Oops, posted in wrong thread.
Astolux lights are manufactured by Matemineco!
Certain ones, but not all.
the S42 is not manufactured by HaikeLight nor will they build a driver for it
Yes, that would work really well as a UI on this light. Like a mini-Q8.
I updated the OP with my NarsilM replacement driver which accepts the USB piggyback board
Can you guys give me a little help? When I switch to Group 2, I only get 4 modes (Low,Med2,High1,High2) and I can’t get to turbo. I want to be able to enable memory so I can start at Turbo mode instead of having to cycle through each mode in Group 1.
Mode group 2 only supports those 4 modes. You don’t have access to turbo in that group. You’ll have to use the default mode group 1 if you want turbo. But, then you don’t get mode memory.
This light has a really weird UI. I’m making my own driver for it.
Lexel, you use the charger circuit that comes with the S42 on your mod? I’m considering making my own with MCP73831, but maybe it’s not needed if the S42 charger circuit is good enough?
I did lift old MCU so charger LEDs dont work anymore. but the charger itself stays connected with the rod and charges
TA made a design with new charging board
Thanks. I think I’ll just go ahead with my own design… it’s part of the hobby after all :slight_smile:
As soon as I hear from TomE to get a me narsil with the new pinout I will release the S42 driver that should be going in all future S42’s from the factory. Never could get narsil to compile properly myself.
A simple FET+1 TA setup but with Narsil it is a heck of a lot better then what it comes with now. Plus should increase the output a lot.
Damn I just ordered a S42! Ahh
Me to :person_facepalming:
I guess I’ll have to mode it with TAs driver when it comes out.
I modded my first one but bought a 2nd one this week. If I’ve known I would wait for the new one. But I think we get better quality driver from Lexel? Not sure if the factory uses the same components as Lexel.
Yeah if they use TAs design and good AMCs this light will be nice
Narsil will then have likely no thermal calibration
My design uses 7 AMCs while TAs is not decided if fully equipped with AMCs
The components on Narsil are not super sophisticated there is no voltage divider for LVP
Caps with X7R is nice to have if it gets hot
Any updates from Astrolux on the new driver version?
Thank you Lexel for the nice review and pictures.
I have this light,exactly the S42S one, and trying today to find the strobe mode, I gave up.Can you or some other guy help to find it out?
Click to turn on.
Press & hold for about 1-2 seconds until the light switches to maximum.
Click again for strobes.
