OK then, I wouldnt purchase ANY light with such 20700 battery size….unless of course my existing supply of 26650’s became obsolete. Who wants to add another sized battery to the arsenal? Most chargers have problems with 70mm lengths as it is… Again, I wouldnt buy it.
I’m into 21700 lights because it seems the largest format that can be comfortably mouth-held.
Also, close to 26650 in capabilities while significantly smaller.
Also, being the next standard it’s bound to receive a lot of development, so we can expect it to be the largest format that has top-quality cells.
Yeah, also what I got, 20700 was “mistake” and 21700 should be produced now.
There are first cells with 4800mAh (pretty good for the size) and in future they promise around 6000mAh
Just putting in my 2 cents worth. It’s 20700, I get it’s not 21700. But it’s a very small for the battery light with a built in charging port. 4000 mah instead of 4800 but still beats the 18650 3500 with the current needed for full LED potential. How often have you run a battery dead walking the dog at night. It is what it is and It’s smallish EDC. My complaint is their poorly designed bezels and NO warranty if you bought from anyone but them on their site.
I haven’t heard of ANY lights using USB-C. This is the first. Then again, I’m not really checking out all the latest flashlight designs. Micro usb can do 2A, so I’m not sure why they are switching. Maybe because newer phones use it?
soo,i never had a flashlight with this led…i am not able to compare it with my second choice Emisar…
but as i know,Emisar is extremly bright only for a few seconds?? so maybe this is more usable…or?runtimes are also important…who is able to confirm it?
I think your getting turned around by the person who made a comment on the video, not the video itself. Blackbolt2099 does not know what he is talking about.
The U11 has 1,050 lumen and the U12 has 2,000 lumen. So the brightness is double.
The U11 has a throw distance of 252 meters.
The U12 has a throw distance of 164 meters.
I think this is where the confusion is.
The U11 has a small hot spot that goes further, but does not light up a big area.
The U12 has a bigger hot spot that lights up a bigger area, but doesn’t go as far.
I tried to find hot spot sizes of both lights and the U12 looks about double the diameter (over 4 times the surface area) of the U11. Hopefully we will get some side by side reviews to see the difference in hot spot sizes.
Have you ever seen a zooming light? You’ll notice that the bigger spot does not go as far as a smaller spot. You can make the hot spot tiny and go really far, but you only see a small area. So you have to decide for yourself what is important to you. If you want maximum distance in a small light you can get a Convoy C8 for about 450 meters throw, but the hot spot is small and not practical for close up use.
I would say the big hot spot on the U12 is great for close up use. I would prefer it for walking around at night as opposed to the U11 which is weaker in brightness.
