I think I’d prefer it use the current ramp’s floor.
I haven’t reflashed Andúril in a while. I’ve been waiting for Candlelight Mode to be perfected. :partying_face:
Has Muggle Mode been implemented? Does lockout work in Muggle Mode? I like the thought of being able to teach muggles the importance of lockout, both software- and hardware-based.
Ah, been a bit distracted by holiday stuff and fixing FW3A issues, so candle mode hasn’t changed.
Muggle mode is implemented but not published yet. There hasn’t been much consensus about how that should look, so for now it’s a simple latching on/off at 1x7135 (~150 lm) with no bells or whistles. I haven’t even made it dim for LVP yet, though I probably should. For now, it just turns off.
How hard would be to do this:
only one mode (100%), it works while you hold down the e-switch, shuts off when you let go the e-switch. Driver is nanjg 105C?
Need this for diving light that had magnetic switch and driver died so I thought to use regular nanjg 105c and replace e-switch with reed magnetic switch!
Siruis9, that should be fairly easy but it’ll need to use something smaller as a code base. The FSM library doesn’t fit onto attiny13 like the nanjg driver uses. I’d suggest using STAR_momentary or Ferrero Rocher as a base, and basically just stripping out features until it’s a one-mode momentary interface.
Oh, the GT will require some additional changes in order to work. Its power circuit functions somewhat differently than the Q8. I’m hoping to get a GT and port FSM to it, but I have no idea when that will happen.
That’s the first time I’ve ever modded a flashlight, so thanks ToyKeeper both for writing the firmware and introducing me to this exciting world.
I’m keen to tweak the C and have a go at implementing some new modes. I’ve that I’m not an expert at soldering though and wouldn’t be surprised if I damaged the D4 if I tried doing it again.
Did I read somewhere that the Q8 can be flashed without needing to solder anything? That might be a good enough reason to get one if so.
Also, is there a definitive list of lights that work with Anduril? I’m assuming anything with an e-switch and an attiny85 would work but it’s often hard to find out what chip a light has. Are there any C8 style lights that might work with it or is the D1s the closest thing?
Congratulations! TK and Andúril got me into reflashing too!
My first-run and second-run Q8s both have wires long enough to flip the driver over without desoldering anything. It’s an awesome light, too!
I’m not sure if the current Q8s allow this. Perhaps someone with a recent sample can chime in.
In addition to the Q8s, I have Andúril running on my Emisar D4, D1, and D1S. I also have it on a modded EagleEye X6R with a Texas_Ace driver from Lexel. The X6R’s design takes advantage of Andúril’s dual-switch option, which works great.
Some more random observations and feedback, after playing with it for about a day:
bike flasher is excellent and means I’ve technically saved money by buying a USB programmer and SOIC clip (compared to a dedicated bike light).
Momentary moon on lockout is handy and good makes the D4 kid-safe
Having 2 different lockout moons (from the 2 ramps) would be ideal
Adjustable party strobe level (eg using using memorized level or bike flasher level) would be a nice to have but realistically, the party’s strobe won’t get lots of use anyway
Good night mode being ramp-able, maybe having a config for time to off, would be another nice to have. I haven’t actually tried good night mode yet though.
A good morning / alarm mode would be very cool. I know there’s issues with power usage though.
Thanks. I guess if longer wires can fit then you could always do a one-off resolder for longer wires if needed. I’d give that a go on my D4 but I doubt there’s space and there’s a good chance I’d damage the driver.
The X6R looks nice. With the cost of getting a new driver for it the D1S looks quite reasonable though.
So far, only a single e-switch is supported… with the option of also using a power switch to make it do momentary-style use in the regular output mode (no need for a separate momentary mode). Without an e-switch it won’t do much.
Two different lockout moons is easy to do; it mostly just depends on whether people think it’s better.
Adjustable party strobe brightness is a little tricky. The pulses are generally only ~4 PWM cycles long. It turns on for 4*512 clock cycles, then turns off. If the brightness is adjustable, it’ll actually pulse 4 times per strobe instead of once. That’s not ideal. Of course, the method I’m using for short strobe pulses already isn’t ideal. I’ve been meaning to make it control the power chips in more of a raw mode, on for N clock cycles instead of N/512 PWM cycles, but that adds code complications because it bypasses the abstraction used to control output brightness. So it locks brightness to a sweet spot on the ramp where PWM is steady, and sometimes stays lit for 4 cycles or sometimes for 5, depending on random factors.
Anyway, um, kind of a long tangent, but party strobe has some known limitations which aren’t trivial to fix.
Making the sunset mode adjustable, and adding sunrise mode, seems like a better thing to prioritize.
I built my X6R before the D1S was available. The smooth, tapered shape is a bit more ‘pocket friendly,’ and like using it with the tailcap switch for momentary turbo while hiking with a headlamp.
If I had to choose between the X6R and D1S, I’d choose the D1S. :partying_face:
Both are good, depending on what you need. One of the main things is to match the beam type to what you’re doing.
From floodiest to throwiest:
D4: ~4 cd / lm
Q8: ~12 cd / lm (?)
D1: ~30 cd / lm
D1S: ~100 cd / lm
For biking I use a very floody light like the D4, and I find the D1 is usually throwy enough for my needs when I need to see farther. The D1S and Q8 are also very good at what they do, but I don’t use them as much because of the size.
Then again, size isn’t always a deal-breaker. I might have a BLF GT on the way (~500 cd / lm), which totally dwarfs all these other lights. It won’t exactly be an EDC, but I’ll make excuses to use it… because that’s just the kind of item it is.
FWIW, I pushed a bunch of changes to FSM / Anduril. A lot of things should be nicer now, but there’s one specific thing I haven’t tested yet and don’t trust. On a hotrod like a D4-219c, I don’t think it’ll regulate down fast enough on full turbo. However, it did pretty well on my FW3A at the highest regulated level, 8x7135. I need to do more testing and tweaking to make sure it won’t burn people with a quad 219c though.
FSM dev branch, getting closer to stable so maybe I can merge it into trunk soon.
Changes:
Made eeprom writes somewhat more atomic, less likely to do weird things if power is interrupted mid-write.
Added a super-simple muggle mode. One level, 150lm, click on/off. Has LVP.
Added candle mode, next to lightning mode. Is particularly nice in the bathtub.
Added FW3A support.
Made lockout moon level use current ramp config instead of whichever ramp is lower.
Completely reworked button debouncing so it’ll be okay even on a really noisy switch.
Fixed LVP / thermal issues (ADC was triggering 4000X / second instead of the expected 4X, which made things weird).
Thermal regulation changes…
Instead of ~85 steps, it now uses 256 or 512 (for a 2- or 3-channel driver). This makes adjustments invisible by eye, but they still show up on a lux meter. Try zak.wilson’s ceilingbounce app if you want to measure it.
Won’t adjust below 1x7135 level any more.
Adjustment speed changes with how far it needs to go.
Added the ability to calibrate the thermal sensor, to reduce issues from the attiny’s per-unit variation.
… and I updated the UI diagram a bit:
The thermal config generally involves a lot of clicks… sorry. Hopefully it only needs to happen one time though, to calibrate the sensor.
It’s been several months since I reflashed a driver, and I’m still a noob. I’m using my notes to compile Anduril, but am running into 300+ errors.
The first is in Makefile line 79 “recipe for target ‘main.o’ failed”.
The next few errors are in main.c in lines 11 to 14 that seem to be caused by some references to folders and .png files in the repository.
The rest are in main.c lines 1500 to 3000 and are “stray ‘#’ in program” errors.
It seems I have a fundamental issue with my workflow, but as I mentioned, I’m a total noob.
Are my errors due to some change in the organization of code and header files? I see that Anduril.c has lots of stuff up top that wasn’t there before. :laughing:
