Banggood system has some kind of flag for wholesalers to mark their accounts. If that flag is set on your account some limited deals won’t work. You can either create new account yourself or you can contact customer service to clear that flag for you if that’s mistake and you are not wholesaler. Of course that second option takes longer so in case of clearance deals it might be too late…
Use coupon code 0fba15 to lower already 40% off price to only $12.23 (original price was $39.99)
According to reviews this light has very high finish quality and it’s equipped with tritium vial (GTLS: Gaseous Tritium Light Source doesn’t need sun exposure to light for ~10 years continuously - after that time it will be twice as dim).
One thing very different from all the other twist AAA/10440 lights is that in order to turn it on you need to loosen the head, tightening the head turns it off.
This design is better for EDC keychain duty as the head won’t get lost because it’s always tightened in off position, also it will not turn on accidentally.
Use coupon code 3a103e to get 37% discount - price drops to $18.87
This is tried design based on prevalent C8 host with XP-L HI LED (1A and 3B tints available) and BLF A6 FET + 1xAMC driver.
This means this light will offer best throw from any C8 host as in turbo mode it’s essentially direct driven - so use high drain battery like Samsung 30Q above for maximum light output (stated 1300lm, spring bypass may be needed).
And of course same great UI as BLF A6 :+1:
It’s now in flash sale for $16.69 ~ $17.69 (depends on LED tint).
Available tints: V2-1A(cool), U6-4C(neutral), U6-3A(neutral), U4-7A (warm)
This version has translucent rubber tailcap.
Convoy L2 is finally restocked (only XP-L HI V2-1A version available so far).
Use coupon code da6f29 to lower the price from $41.99 to only $21.41 (-$20.58 / –49%)
This version comes with 2 cell extension tube and can be used in both single- and two cell configuration.
That is a great deal on the L2, but they are still out of stock, and it looks like they will be until 1/10. Any way we can pre-order or something to lock in the price?
