You can get IR leds from Mountain Electronics. For the S2+ you will need a 16mm MCPCB/Star.
Currently the 850nm version is not available, only the 940nm version.
There is a warning in the product page you must follow, so you should also get some non-conductive thermal product:
There is a 850nm led available in kaidomain , it doesnāt show any warning but I would expect that the same goes for it.
There is also a OSRAM led in fasttech , but only in 20mm or as bare led. IR leds are not hard to find, so I would expect that any of the more specialized electronics companies you can find in the forum would have them as well.
MtnElectronics recommends no more than ~1A maximum current for the leds (3x7135=1.05A is ok). Unless you know better or donāt care if the led dies I would follow that recommendation.
Led4power has brand new emitter boards that solve the problem that Oslon and Luxeon IR LEDs have non-neutral mid pads. (20 mm boards so you will have to mod the pill and maybe the board)
Their drivers are a bit overkill as your maximum current will be much lower.
You may use a genuine 17 mm Convoy driver and reduce the number of 7136 current regulators on it.
Those Oslon and Luxeon Emitters can work on DTP stars
But you need a driver that has the battery positive on the tail and ground on the driver spring
the Biscotti Attiny 13a should be fine with a drive current of 1.4A if played safe and 2100mA with driving LED harder, but should be good on DTP
I did such designs
depends on the gear he uses, most NV and cameras only get high brightness with 850nm
Those quality 850nm IR LEDs have almost no visible spectrum far better than even Nichia UV ones
IR LEDs also have not the white wastelight issues like many cheap UV LEDs
First question should be (IMHO): what do you need it for?
With UV itās simple. Though it can damage your eyes, you cannot really see it. But you can see the reflection of it.
IR you cannot see, nor the reflection of it. So you need something to see it with.
Do you own night goggles or do you use a camera. First you have to determine at what wavelenght these operate.
The usual suspects are: 850nm and 940nm.
Only then question two is in order: how do I achieve that (see previous posts). Light, LED, driver, et cetera.
if you insulate the stars back and screws you can use a normal XML2 C8 7135*6 to use as host for like 14$
all you need is solder iron, some Kapton tape and small insulation washers
also filing the screw slots on the board wider so there is no risk the screws touching the LED board
Itās just like playing the game for the first time, you get shot several times but each time you learn what you need to watch for
Btw, you can just use cheap non-DTP MCPCB to solder led and a bit weaker driver (donāt push the led so hard), then you wonāt need kapton tape.
Yes, but you need 16mm MCPCB for S2+ and maybe use SMO reflector.
Thanks for all the responses guys, I really appreciate the help!!!
Just fun to have one.
And I have modified a Sony Nex3-N camera to full spectrum so that camera will be able to register the IR light.
If the LED still produces some light in the visible spectrum itāll get filtered out by the 850nm pass filter Iām going to use. Iāve also done this with my Nichia (365nm filter of course) and it has reduced the visible light to a minimum.
You mean 850nm
So what are you going to do with them?
Iāve thought about buying all parts to make my own but I have no idea about drivers etc. I even had to look up what DTP means
So all the help offered with regards to building one myself is much appreciated but I still have a lot of catching up to do.
Looking at the size I need, I think this model may be easy to have its guts transplanted to a Convoy S2+ $10 18650 IR flashlight on eBay
However, thereās not a word on which LED it contains and its rated power is probably bloated.
If the battery is connected directly to the led and the forward voltage (Vf) of the led is lower than the voltage of the battery, then the led will take an huge amount of current and will likely be damaged. As a general rule the higher the wavelength the lower the Vf, so IR leds have a very low Vf.
The driver regulates the current so that doesnāt happen, also controlling modes in flashlights with several modes. Lineal drivers burn the excess voltage as heat to keep the current regulated. They are somewhat inefficient for low Vf leds but they fit in small flashlight and are cheap so they are quite popular. 7135 chips in linear drivers are connected in parallel and each one allows passage of 350mA of current (in some models 380mA), so a driver with 3 7135 chips will give 350x3 = 1050mA = 1.05A of current to the led.
DTP means direct thermal path. It means that the star (also known more formally as MCPCB) has copper or other highly conductive material underneath the led that continues all the way to the back of the star, so the heat can go quickly from the led to the back of the star and then to the pill, avoiding overheating of the led and allowing higher currents. The problem is that copper conducts electricity as well as heat. Thatās not a problem for cree or nichia leds, but it is for OSRAM ones.
In that case I would get something like Manta Ray Osram IR850nm and just use it as it is. Unless everything fits exactly, ātransplanting gutsā is not easier than making your own in the first place.
Ah cool. So this is regardless of the voltage you supply?
So an LED with a 1.2V forward voltage can be driven by either a 1.2V NiMH or a 3.7V Li Ion and use a constant current of 1.05A when using 3x 7135 regulators?
Thatās the most basic thing I need and I assume a controller chip with firmware is only used when you want more modes on a flashlight?
Thanks for the useful information.
Thanks for the tip, Iāve ordered one anyway. Itās cheap and Iām certain to get an Osram LED. Perhaps if I take it apart and see how itās done I find it to be no problem making one myself.
In principle yes for the concept of linear drivers, but I donāt think there is a led with such a low Vf. In practice 7135 also have a bit of voltage loss of their own, so the battery voltage has to be a bit higher than what the led requires. AFAIK they canāt handle more than ~5.5-6V without modifications and as Lexel said, they need a minimum voltage to work as any electronic component.
7135s adapt their resistance automatically to try to keep the current constant, so they donāt need to be finetuned for the Vf range of each led. The Vf is a function of (desired) current or in other words forward current is a function of the voltage that reaches the led, for example a led could take 700mA at 3.0V, 1050mA at 3.2V and 2800mA at 3.6V. If the battery is at 4.0V a driver with 3x7135 will transform the extra 0.8V into heat to keep 1050mA, one with 8x7135 will only need to transform 4.0 - 3.6 = 0.4V to keep current at 8x350 = 2800mA. When the battery (counting losses) goes below such voltage the current will fall accordingly. See for example this test by djozz for the Vf curves of several white leds (the lines in a lighter shade are Vf as function of current, the solid colors are output in lumens).
If you want to run a led with one or two 1.2V batteries you need to use a boost driver. They increase the voltage to what is needed. I donāt really know much about boost drivers. AFAIK small boost drivers canāt handle much current but they may be able to handle 1A output current.
