Me as well.
A little more this arvo wired the magazine
hopefully nothing will explode
Looks good. How big is the diameter?
I see you have your nuts showing there. :person_facepalming:
[quote=MRsDNF]
56mm .
Coming along nicely.
A little more progress today
mounted a alloy hyd cylinder in the lathe
did a little knurling and madea square thread
trimmed it off in the hacksaw
cleaned it up in the lathe and bored it out to suit battery holder ,pictured with what will be the head
What pitch is your square thread?
I guess you wont be out in the shed today because of the heat.
2.2 mm
a little progress today made a retaining ring for switch it will be held with a few screws from the rear
so I will now have to rewire the battery holder
next time we will start on the head.
Were you planning on using an e-switch? The tail switch is now the main switch or lock-out function?
tail clicky only,was going to be in the head but would have made the light longer
Nice work LTP!!
Nice progress
Internal thread completed
Took a little to make it fit ,but happy now.
So that knurled part is 80mm in diameter?
had a few minutes ,thought I would add fins
they start at 3mm deep and finish at 10mm depth
3mm spacing , should keep it cool for the first 5 minutes,
try and do a bit more tomorrow
knurled handle 70 mm dia.head 85
Are those threads square or trapezoid? How did you cut them?
Is that a phone picture?
yes square thread pp ground my own tool slow and steady
next bit is a little boring
ended up with this
spun it around just want to shape the head a little,not sure how yet,
next week,.
and yes mrs dnf all pics are from the s5 as it is easy to upload with the app,
lostheplot
Do you have a mill?
