I know that I will be hitting turbo a lot… It’s a hot rod!
But I also will use lower levels a lot too. It’s amazing how often you use a light. It’s like a leatherman or a watch.
I wonder how the threads will hold up to changing batteries a few times a week haha
How they have a max drive current of 5A?
It is a direct drive flashlight, there is no 5A limit per LED or any limit whatsoever in terms of current, it is going to be as high as the sum of all components in the current path allows to
But yeah that instant current on high drain fresh cells with a cold head might potentially kill the LEDs.
I’m curious why you mention that high current “with a cold head” would kill the LEDs. Is that because a low junction temperature at the LED results in a higher current than when the junction heats up and causes some additional resistance?
Or are you referring to the high initial current, before the driver detects the temperature rise and ramps down the output?
If it’s just the latter, well, isn’t the light designed to handle that current? I know it’s way beyond spec, and will cause faster aging of the LEDs, but hopefully it won’t fry them!
Anyway, I’ve been using FET-driven lights in very cold temperatures (–20C or colder), but should I be concerned about turning them on max when it’s that cold?
That’s where I purchased My Aspire 18350’s also. Ordered them when I ordered the D4 a week ago. I have already received my 18350’s. Hank did send a shipped notification email today. I didn’t receive a tracking number even though I paid the extra 2 bucks for it. :person_facepalming: I emailed hank. We’ll see how that goes.
I Don’t think there is a better 18350 cell on the market at this moment. Im going to try the Sony 18650VTC6 when they get here also.
