I expect that’s directed at me… no this isn’t about trolling… it’s about changes to the GT which me (and I presume others) were not aware of, and which potentially may well be a deal breaker based on expectations set prior to ordering.
Come on. No one has really been picking a fight with you. In fact, we have more of a friendly attitude than is being asked for.
Oh, that one is easy. As was already pointed out a dozen times, the newer and warmer version is in fact better, not worse. It will not be disappointing IRL, all but that.
Thanks for that… really appreciate the information, and especially the welcoming non-accusatory tone it was written with - thanks.
It wouldn’t be right to make a final judgement until I’ve tried it out… but the video really worried me because of the visibly huge difference… and then to find the change in LED had been made without anyone other than seasoned daily followers of the thread knowing… well that annoyed me from a comms perspective.
I’m sure many have worked hard… but I’m afraid that something like this can and does (justifiably) ‘spoil’ the experience… just like you ordering a new red car like you saw at the showroom… and it arrives a notably different shade… it’s a mistake which shouldn’t happen. We should have all had emails prior to orders being taken to update us of the change - to give as the chance to make an informed decision at that point of what we wanted to do in light of the new situation ref LED change.
It’s not hard, in fact it’d be really easy to answer… but I’m thinking you’re asking something to question, critique or otherwise cause trouble… and I don’t want that…
It would simply reduce the red and green wavelengths, and make the beam almost not visible.
The reason cool white LEDs have a much more visible beam is because they output a lot more blue and green light.
I would love to see that to Joey.
Especially if it was done in a controlled manner as the Neat Test Dale (DB Custom) Did . That actually shows something where ’the rubber hits the road’…… the target.
Theory is one thing, and not a bad thing either; but seeing it makes it real… to me anyway.
And the photo of beamshot on target, taken at target…… is hard to beat.
Fantastic Dale!! Kudo’s to you…… :+1:
. Post #13932 / DALE’S (DBCustom) MOST EXCELLENT TEST…. 1.3 Mile Beamshot on target photos.
It only effects run time. This is a buck driver, it take the 16.8 volts and regulates it to a steady lower voltage (13 something volts, I can’t remember the exact number). So as long as the batteries stay above that specific voltage, the driver stays “in regulation” and it can deliver max power.
Once the batteries drop down in voltage (below 3.5v ?) it drops out of regulation and can not produce full power any longer so the output slowly declines.
4 30Q cells gave 45 minutes of regulated power at 2A then another 45 minutes of reduced power before the lvp kicked in. So 8 cells should double those numbers.
Maybe someone can chime in with the exact voltage this drivers drops out if regulation at.
This is a subjective opinion, not a fact.
“better” will depend on what someone prefers.
Just like 10k lumens and 100m throw isn’t better than 100 lumens and 10km throw, it completely depends on what the person wants.
I will also point out that a lot of people who tested/bought the GT mentioned how much everyone they showed it to was amazed by the beam, including themselves.
Oh, it seemed like you were going to criticize him if he didn’t have many flashlights, or didn’t have any warm white flashlights, or something like that.
I never got the feeling that LuminousIgnis was trying to set up an attack on Spartan16 by asking what lights they have. If anything it could offer some insight into what tints and temperatures they have personally experienced.
I think you are being overly critical. I don’t see where anyone has asked for “another blue light for mindless consumers”.
Neutral white is just that Neutral.
Not “Blue” & “Not Yellow/Orange”.
